« 1 2 (3)
Re: How to Choose and Tune Weber Carurettors : Basic Understanding
yeh, 140-150 rwhp is very impressive.
in regards to tuning,havent got info on how to tune during different seasons like summer or winter...
Posted on: 2011/11/21 10:40
Good to know no emissions to abide to.
thanks for that info cylons8.Can't wait to one day hear this induction noise.Here is i pic i took at a toyota gather up last sunday.car was a 240z but like the 'air box'.So roughly how many times a year does one need to tune carbs?
jpg  airbox240z.JPG (150.46 KB)
15239_4eca2e053a763.jpg 600X450 px
Posted on: 2011/11/21 10:55
From Near Bundaberg QLD
If you run a dry paper element air filter you will find you will have to tune it a lot less often, as the oil on foam filters (Sox etc etc) will get everywhere and gather the minute particles of dust that manage to make it thru the filter.
Posted on: 2011/11/21 11:00
Thanks, Sam-U-El/Racer135
4 utes, 1.5 sedans, 2 120Y sedans, 1 C120, 1 1600 sedan, all look like or are wrecks
Run paper filters like the rectangular redline ones and then run socks. There is a noticeable difference.
I'm not sold on the paper filter theory and if there is any sort of accumulation, to that effect then it is negligible and not contributory to the carburetors going out of tune.
The oiled foam filter elements should be oiled so that they are coated and not saturated, they should also be washed regularly. I insist you avoid paper element filters, there is good reason why the high performance gear is foam filtered. If you oil them right, use the right viscosity oil and wash them regularly they should serve you well. An air box with a replaceable paper filament is very neat though.
When the carburetor goes out of tune this is largely due to the linkages slowly loosening, slipping or going out of adjustment (worse case scenario is they bend but this is a sign of another issue altogether). Your carburetors will go our of tune from general wear and tear but this is over a fairly extended period of time- we are talking worn throttle shafts, hesitant bearings, twisted throttle shafts and such so this only happens over an extended period of time (looooong term).
The mixture adjustments can also change slightly but this depends on how well you isolate the carburetors from vibration (soft mounts) once again fairly minor change (unless you have another issue that accelerates these changes). A good set of softmount will do well for vibration isolation and thermal insulation. The phenolic spacers from Toyota Mikunis, Bpro and Nismo are my favourite. You can also argue that an aggressive cam brings the shakes on hard and subsequently contributes to a quicker decline in the precision of the adjustment, that's being a bit finicky though, ignore that.
So generally if your throttle linkage gear is fairly simple, like the ones offered by bpro, nismo, datsun competition, sytec, magard you will have fewer moving components and therefore fewer moving parts to loosen up. Loctite on the throttle linkage arms (adjustment nuts) is a good idea but generally I don't adjust from those, I just set the adjustment from the idle screw, set the throttle arms and then go from there. The redline kits mount off the manifold and they aren't as robust as the integrated throttle bar linkage setups like the bpro/nismo/datsun competition manifolds, so they are more prone to going out of adjustment. May I ad, I think the newer redline gear is absolute shyte.
Generally after you first set them you might find that the linkages do move a little bit as they are pressed hard when you go for WOT, and they do move over time so a readjustment quite soon after you first have them running is quite normal. This readjustment will almost certainly only involve just synchronization and not a mixture adjustment (unless required).
The truth is they only go out of adjustment if the adjustments don't stay put, a carb can't really just go out of tune just like that, something normally has to move (or break or bend or twist).
It's a shameless plug, I know, but if you need help with the carbs to be rebuilt I can help you with that here. Mind you I'll be in the tropics for the next 3 months so not possible until next year.
Posted on: 2011/11/21 12:34
If he's still around (he'd still be alive for sure, but I don't know if he might have retired or not) then Brian Pope (I think that's the right surname, it's been a while) down at 'link automotive' -(also known as mini-link and mini link automotive) - is a gun with webers. Naturally he's got most experience with mini a-series engines, but an a-series datto won't exactly be a 'new experience' for him afaik! They were down in Thornton Crescent Mitcham, and I think the number was 9873 3874 - if that doesn't work, google them :)
Posted on: 2011/11/22 7:04
John McKenzie
thnx jmac!
Posted on: 2011/11/22 9:25
When it comes to all things carby related I would advise to have a chat to Nigel at 'The Carby Shop' before you even purchase a set up. He can tell you what to look for and even advise you on whatever you need really. He is the only bloke I would trust to do a carby job for me without asking the 'why' question. He is the best.
Nigel. The Carby Doctor. 5 Sherwood Court Wantirna South VIC 3152
(03) 9801 3984
Posted on: 2011/11/29 7:33
« 1 2 (3)
