what rpm for 3 speed auto?
From vic
hi i was wandering with my 3 speed auto with an a12 at 80km/h it sits at 3000rpm and at 100km/h its around 3200rpm im guesing this is normal as the transmission reaches 3rd gear. But it seems a bit high to me?
Thanks!
Posted on: 2011/11/21 13:00
Re: what rpm for 3 speed auto?
From sydney.nsw
you may have the wrong diff ratio. how does it take off in 1st.
Posted on: 2011/11/21 17:54
A.T.E RACE ENGINES: ( " AUST 1 " 2010 ) A15 GO THE DATTOS... 0412 864 741
From vic
hi well in first gear it takes of preety normal. Any ideas what rpm should it be roughly around?
Posted on: 2011/11/21 23:23
sounds good to me from a 120y with the heaver body
otherwise the economy wont be flash.
Posted on: 2011/11/22 0:06
From vic
thanks for the clarification.
Posted on: 2011/11/22 0:09
My old datsun 1000 vb10 sat at 3200 on 100kph
and had good economy same as the kb10 coupe
I had so if you think its too noisy then you
could go for a 3.7 or 3.9 if it has the 4.11
at the moment but if it has the original diff
ratio in her you could try slightly larger
diameter tyres or wheel combo.
Posted on: 2011/11/22 1:41
The A12 can cruise at 4000 RPM all day, so it is good to go at only 3200 RPM.
Posted on: 2011/11/22 4:11
