« 1 ... 5 6 7 (8) 9 »
Re: Evan's 73 Coupe project
From Seattle ,WA.
Time for some more updates - I had to pull the engine.....TWICE!!! since the original install, first time was stupidity (didn't flatten the oil pan flange prior to reinstall & guess what-oil leak, dumb huh), 2nd time wasn't my fault - didn't matter I still had to fix it (rings in #2 didn't seat, low comp).
Back in & running better now, some progress pic's
entered in the Edmonds car show in Sept.
you can see the oil pressure gauge under the left side of dash - I installed a T at the pump & ran the gauge off one side & the sending unit off the other - works great. If anyone ever does this make sure you use British Pipe Thread fittings not SPT.
my new Grant steering wheel
not sure if you can see this but I tapped a pcv system into the Cannon manifold, its still ran from the crankcase breather to the catch can then back to the mani..
console & clock going in,
all for now...
Posted on: 2011/11/24 16:14
From Seattle ,WA.
no more catch can, just a pcv system now w/a valve cover breather, seems much better - no oily venting into the engine compartment. I dont have a pic but I just plumbed the PCV directly from the crankcase breather pipe to the manifold.
Did get the console installed with the clock, we'll see how good a time it keeps.
heres my oil pressure gauge, I put a LED light into it & man is it bright! Adjacent to it is the switch for the rear window defroster I installed as well.
heres my mirrow w/compass, temp & lights - oh yeah, auto dimming - work damn good too! Being a low car somebody's brights would be a bit*h otherwise
and it has map lights
Posted on: 2011/11/28 4:13
From Snohomish, WA USA
Looks great Evan! Good Job!!
Posted on: 2011/11/28 6:51
'73 2 Door Sedan
Crower Stage 3 Cams/SS Valves
Forge CP Pistons/ Eagle Rods
Ford 8.8/Mini Spool/4.11
From Seattle ,WA.
Thanks Ernie! I want to see your ride, maybe at the Nissan meet at Shilshole in feb?
I dont think I ever mentioned the spec's on the drive train so for those that want to know:
1980 A15 bored .030 over
Delta re-ground cam "KC" grind -
http://deltacam.com/
H72 head, double springs, somewhat ported intake runners matched to manifold
Ceramic coated header going into 2.5" collector necked down to 2.25" on out
Tomei intake gasket
Weber DCOE 40
60A 5 speed trans I rebuilt
H150 center out of 1980 210 w/60K miles on it so still pretty young!
Brad Penn breakin oil & Redline synthetic trans & rearend fluids
Posted on: 2011/11/28 16:27
Yes. Let's get together soon. Got my header in the mail so that's my next project.
Have a couple more gauges to install on the top of my dash. Lean/Rich Ratio and Fuel Pressure gauge.
Fun stuff!
Posted on: 2011/11/28 17:06
'73 2 Door Sedan
Looks great! Get a pic of Pcv set up too if possible. Nice little touches like digital stereo and mirror don't detract from car much at all too.
I see you were served your balls on the back seat. You missing one
Posted on: 2011/11/28 20:22
From Melbourne, Australia
sexy as!
is that orange material on the top section of the door trims?
it gives the appearance more like like sedan trims that dont go all the way up the door,
Posted on: 2011/11/28 21:39
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From Seattle ,WA.
I thought 3 balls in a set was normal, something wrong with that
Your right, the orange is on top of the doors, I painted it that way & re-made the door panels w/o the metal cap/top piece of the original door panels. I guess thats the style of the sedans & the utes I think. I just thought it'd be nice to have a touch of color in the car as well.
Posted on: 2011/11/28 23:31
Not too shy to talk
From Gilbert Arizona, USA
Wow, what a great looking car, great job. You should be very proud!!!
Dale - AZ
Posted on: 2011/11/29 0:22
Orange and chrome are made for each other probably best orange coupe Ive ever seen in photos, amazing attention to detail congratulations!
That grant steering wheel and radio are amazing touches.
Posted on: 2011/11/29 1:16
