« 1 2 (3) 4 »
Re: e16 crank
Its a good point Dylan, I always wondered what the difference would be
with the e16 and ga16 since they have the same bore spacings. What do
you think Gary? The ga16de head lines up on the A series as Feral was
doing in the past and yourself also.
Posted on: 2011/6/4 4:42
Re: e16 crank
From Kaarina.Finland
Hier some photos,how that engine look like,with E16 crank and E15ET-cylinderhead.
http://kuvablogi.com/nayta/2935343/ and 6 photos more.
And littlepit more http://kuvablogi.com/nayta/2914570/ +4 photos more. etc.
And finalphoto is that:
http://kuvablogi.com/nayta/3104451/
The timing chain is do that whay in that race-engine.
Posted on: 2011/7/2 22:31
Re: e16 crank
gonna be another finnish beast is it finished ;)
Posted on: 2011/7/3 4:28
Re: e16 crank
From Central Vic
Bump
Has any more happened on this subject it looks good
Posted on: 2011/11/22 11:07
to buy or not to buy???? OK
This is the reason I have five coupes
Re: e16 crank
From USA
This is really interesting. I wish we could hear/see some more details on what needs to be done to an E16 crank to get it into the A-series block. In the rear is it just machine work to cut the E crank to the A-series rear main seal size? or is it more than that?
Posted on: 2011/11/24 14:40
Re: e16 crank
From RSA
yes this is a great topic ---as i'm finshed with my 79mm piston screamer i would like to look at something like the above or fit my uno turbo motor. datsun has first op's.If somebody can google this info it should help.--from Oz. google wet-sleeve engines --go down to cylinder sleeves and cylinder walls --video.then further down to engine blocks & cyl sleeves:engine builder. then also DARTONSLEEVES :what is MID
Posted on: 2011/11/24 16:28
Re: e16 crank
I was a little bored, so I ended up typing a bigger reply than I originally planned. Here it is. As usual, I'm not perfect, and the stuff below is based on thoughts/opinions/ and experience, but it doesn't mean it's all 'the best' info or whatever. Read it on those terms please.
There's some good info on the darton sleeves page, but I'd 'maybe' add a couple of things. I haven't tried this specifically on a datto engine, but there are some issues that might crop up in general.
First - the sleeves are strong - I'm definitely not questioning that. BUT the more you take out of the block, the less there is remaining to help the threads where the head bolts attach - and any flexing there and the sleeve might be 'great' but the head gasket sealing might not be any more. And yes, you could run various types of o-rings and or custom gaskets, which will (generally) seal in the compression/combustion pressures in the cylinder - VERY VERY well, but often tend to seep coolant everywhere else (albeit usually fairly minor.
Even if the sleeve itself is very rigid, you can get side thrust to the point it tries to push the entire sleeve. Now I have to aay that they way they've designed them they sort of 'slot' together and would be pretty good, but you might find that it is necessary to also 'post' the block. what that involves is drilling and tapping the block outer walls, in the midde of each cylinder, on the major thrust face, then with specially machined bits of 'thread' (and opinions vary on what to make them out of) you then screw them in (with a flat/slightly radiusd tip) till they only _just_ barely touch the outer wall of the sleeve.Any further and they can crack, or distort the bore etc. This sort of thing has been done on honda b series engines when they go for larger bores (and occasionally longer strokes -which end up with considerable rod angularity and more side thrust.) It's also been done on older 'dinosaur' v8s (I've heard it was done on factory cleveland v8 blocks used in the early days of pro-stock. They had arguably borderline bore wall thickness - fine for 99.9% of uses, but when they started spinning them well in excess of 8000rpm, even in excess of 9, some people resorted to this extra step. I believe they also bored them out, then pressed in sleeves ('so called dry type') so that the bore wall thickness was the thickness of the sleeve, not that of however the block was cast.
I've never actually seen one done like that (this was US pro-stock stuff, and happened when I was an infant, so understandably it's not likely I'll ever see it in real life here in Aus!)
Although having the sleeve walls touching between each other does lead to more strength (if the block is cast like that it is called siamesed bores) some people argue it also means less consistent cooling around the entire cylinder. This would also tend to mean that as it heats up the expansion won't be 'round' it'll be more oval shaped. There are ways around that (including heating it all up to approximate engine running temps, and then doing the final hone). And there's more than a few race engines out there (chevy bow-tie blocks were siamese bore, also massively thick bore walls - could be bored over 0.125" oversize to a 400sb bore size, and I think some ford motorport blocks were too, but don't quote me on that). In contrast people seemed to have more issues with older chevy factory 400 blocks, with their siamese bores, but I think it might have been down to the fact they were a mass produced low-performance setup (the 400s as they left the factory, not a 400ci combo built from the bow-tie block or whatever) and so the 'production values' and controls were tailored to meet that much more modest set of criteria.
On the darton sleeves page, they mention a 'protective coating' on the outside of the sleeves, so the coolant/water doesn't corrode them too quickly. Based on what they discuss, it's probably just an application of phosphoric acide to the outside of the sleeves. This still is also marketed as 'de-oxidene' and a number of 'rust beater' or 'rust convertor' names. The stuff works. It isn't magical, but it does work. I'm not a chemistry guru, but I believe that what it does is effectively convert the surface layer of the metal into iron phosphate (or something along those lines). This is a (relatively) hard material, and is resistant to corrosion. If prepped and done right, it will end up forming a surface layer or barrier and help prevent oxidation of the metal underneath that surface. It's certainly better than nothing. I am curious as to where and how close to the top of the sleeves they apply it. In theory, this surface layer might end up changing the outide diameter of the sleeve (even if only microscopically). I'm sure they will have worked that one out, so I'm mainly saying it incase anyone else tried to diy their own sleeving. It probably wouldn't be enough to affect sealing/fitment, but I don't know for sure. This is a hobby where (in some situations, esp ultra high performance) less than half of one thousandth of an inch ( 0.0005") difference in size can be the difference between
success and failure.
Another thing I'd raise - if you go to a stroker crank, and one that you intend to rev high. The full counterweighted crank of this donor engine's crank is definitely a good thing.Yes, technically it is a little bit more mass, so it would have slightly less throttle response than if it only had counterweights like the a15 crank. BUT those extra counterweights smooth it out and should help keep the crank together at high rpm. If it was all out drag racing, where the motor didn't have to last more than maybe 10-12 minutes of full rpm full htrottle stuff between rebuilds then sure, go with the lighter option (even consider machining down the counterweights a little bit).
But for any engine where maximum engine life is a big deal - go the counterweights. Which leads to the next related thing - the front pulley. Most 4 cyl engines out there usually (or at least they used to) have just a 'pulley. No harmonic balancer (no crank dampener). It's not such a big issue on regular sized 4cyl engines, esp if the stroke isn't too long, and the revs aren't too high. But in a case like this - the longer the stroke, the more the crank can 'twist' end to end. It's not a huge twist, but it happens, on whatever level. SO again - whilst a smaller pulley will have less intertia, and have better throttle response, for longer crank life, what you really need is a proper dampener.
On the mini a-series engine, the 998s and 1275s have just a 'solid' pulley. On hte 1098, which actually has the longest stroke of all mini a-series engines (and smaller main bearing diameter, so more chance for crank flex) they had a 'proper' damper - a solid outer hub and solid inner one, and some sort of rubber inbetween the two. Much like the std balancers on holden 6s (the old red and blue 6s - which were basically a smaller engine, very similar in design, but no parts are actually interchangeable (afaik) as the chevy inline 6s (the ones with siamese intake ports and a head bolt running through the centre of the intake ports) and a bunch of other engines. I used to run the 1098 dampers on the 1275 engines I ran.
I don't know if there's anything off the shelf to suit it, but if there is, I'd definitely run one. If not, I'd look into finding one that fits some other engine (be it inline 6 or another 4, or whatever) and machining/adapting it to a 'big bore big stroke' custom crank engine. On Aus made hemi 6 engines (which have crank issues around 6100rpm - they are fine if you keep them above or below it, but sticking around that rpm point for extended period isn't a good option) there's a couple of aftermarket 'steel hub/rubber ' type balancers out there. But one guy went to the trouble of doing a production run of a custom hub/pulley - that would allow the fluidamper ( a fluid filled variant of the basic design) from a perkins diesel motor to be attached. Most of the 'traditional' 2 piece / rubber insert balancers work good, and tend to work best at one particular rpm range, and still pretty good elsewhere, but the fluid-filled style, they work very very well, and at practically any and all rpm ranges..
If I was trying to do a high revving hybrid crank a series engine - I'd definitely consider trying to adapt a fluid-damper style front pulley. But if that was too hard to achieve, at least I'd try for adapting a solid inner/outer hub with rubber insert type. When you start to add up the costs to do a stroker motor with this crank, well the $$s are considerable, so the extra cost of a good damper on the front is not really that much more expensive.
One of the signs of needing a better balancer at the front (though there can be other causes of this) is if you constantly find flywheel bolts coming loose, or worse still breaking/or the back of the crank snapping. It sounds 'crazy' that the 'damage' at the rear of the crank is caused by what is at the front of the crank (or what is 'not' at the front of the crank and needs to be put there!) but that's the way it goes.
I make no secret of the fact that I like boost - either turbo or supercharging - for the best value for money hp increase (and done right it can be achieved while still getting stock engine lifespan). That's all nice, but I have to say, I really admire the guys who push the limits of engines/development, but naturally aspirated (i.e. no turbo no blower, no nitrous etc). It takes time, money, massive effort, dedication, and behind the scenes, non stop testing and development - for example they might go through a bunch of engines, just finding the limits, and getting the most out of it.
Posted on: 2011/11/25 12:55
John McKenzie
Re: e16 crank
From sydney.nsw
well said john; the other problem i see, is the rod alignment to the middle of the piston pin (when bores are offset in a big way)for that big bore(80mm+). unless custom making a new crank to suit offset bores. $$$$
Posted on: 2011/11/25 21:52
A.T.E RACE ENGINES: ( " AUST 1 " 2010 ) A15 GO THE DATTOS... 0412 864 741
Re: e16 crank
The big issue is the e16 crank is rare here not in the US
but the GA16DE is the son of rthe E series like the E is
of the A series so will th GA16DE be compatible for the A?
GAs are a dime a dozen
Bige / Jmac I think an offset ground A15 crank to 86mm
would be enough for boost since you dont need big revs.
Crankpins to 40mm then use E15et rods with arp bolts and
a bike or custom piston gives good rod ratio in return.
There are many bike pistons available with 25mm comp height
at 78-81 from Suzuki, Honda and Kawasaki last 10 year engines.
Posted on: 2011/11/25 23:40
Edited by D on 2011/11/25 23:58:58
Edited by D on 2011/11/25 23:59:22
Re: e16 crank
"well said john; the other problem i see, is the rod alignment to the middle of the piston pin (when bores are offset in a big way)for that big bore(80mm+). unless custom making a new crank to suit offset bores. $$$$"
Ernie I missed this but critically good point. In theory if the bores are say 83mm (using ca18de pistons with stock a15 rods or shaved ca18de rods as they have wider bid end) so 2 and 3 bores are offset inwards to suit this there is also a small issue with the combustion chambers but potentially bigger one for the mentioned conrod not aligned on the piston pin centre. Could this be remedied by using shaved Ca18de rods (133m and same big end bore as A series) but shaving more on one side than the other?
Max bore on some A15 engines with lots of meat is 79 to 80mm so for 1.5mm extra each side this would equate to 2-3mm offset inwards on both sides to fit the full sleeves? Im still salivating on the though of a 1775cc A series.
http://gasketstogo.com/quotations.htm look interesting
Posted on: 2013/5/23 5:47
« 1 2 (3) 4 »
