Whats a good single carb for a a12?
What is a good carb for my a12 with a std manifold and std engine?
Posted on: 2004/3/7 12:43
To do something well is so worthwhile that to die trying to do it better cannot be foolhardy. It would be a waste of life to do nothing with ones ability, for I feel that life is measured in achievement, not in years alone.... Bruce McLaren
Re: Whats a good single carb for a a12?
From Coondle, WA Australia
32/36 if you can find the lynx adaptor for it.
try redline for it as lynx dont exist anymore
Posted on: 2004/3/7 12:55
EARTH FIRST! - We can mine the other planets later...'
'69 Blue 4 door Project Daisy (http://www.datsun1000.com/TopicView.asp?TopicID=668)
(https://pcmhacking.net/forums/viewtopic.php?f=15&t=5640)
(http://mx5cartalk.com/forum/viewtopic.php...
From Mandurah WA
32/36 would be a bit big for a a12 i would look into a corolla carby or similar..
Posted on: 2004/3/7 13:02
1984 Mazda 626 stocker..
Soon to be 32/36 weber powered
now that you put it that way, yore probaly right. My a12 is not normal i guess. A 1600 corrolla carby woulnt be a bad choice. dont know how easy it woul be to bolt up. not sure what they use.
perhaps a carby of a L16\L18 datto or something. they are a bit bigger arnt they?Edit : you could always jet the 32.36 down a bit though.
Posted on: 2004/3/7 14:59
From Canberra, Australia
32/36 weber or G180 Holley (Same thing basically)
Buy a redline adapter from your autobarn/autopro type store and bolt it up. May need to get a linkage made depending on what carb you get.
Can normally find webers on some of the older fords. I am not exactly sure of the makes... Someone else will know...
Posted on: 2004/3/7 15:57
1971 Datsun 1200 Coupe
A15 Engine. Holley G180 (32/36 Weber). extractors and 2 inch exhaust.
Standard 1200 4 speed with lightened fly wheel and HD clutch
Stanza front struts and brakes.
15x6 CSA Wheels with 195/50 rubber.
a ford fanatic friend of mine reckons that the xd/xf/xe 250 crossflows came with em, but not sure. it might just have been his ute.
Posted on: 2004/3/7 17:52
Hitachi DCH-306. My new 1200 runs great with it. My old 1200 ran superb with it. The Weber won't give any improvement except above 5,000 rpm.
Posted on: 2004/3/7 19:07
Since the question was not asking for performance modifications, then it should be a simple choice. The original series of carburettors were designed to fit, & work with these engines.
I have always prefered the slightly later electric choke versions as this wonderous invention lifts the burden of knob pulling,... & pushing,... & needing to tax my grey matter on when to pull or push.
Rebuild an original series of carb. On a standard engine, there is nothing that really offers more.
Posted on: 2004/3/7 22:46
Love your Datsun.
Treat it well.
From Lethbridge, AB, Canada
Whats the difference between the Hitachi DCH-306 and the DCG-306?
Its a DCG 306 in my Sedan is the DCH different or is it just a typo?
Posted on: 2004/3/8 2:06
'73 Datsun 1200 Sedan Turbo A12
From Canada
I believe the G is manual choke and H is electric. Otherwise the carbs are identical. I know the old stock 1200 my bro had way back ran great with the stock carb on it.
Posted on: 2004/3/8 3:01
