« 1 ... 5 6 7 (8) 9 »
Re: RUREDI's '71 Datsun 1200 Coupe (KB110) - GX CLONE
This might give you some idea of potential for your combo, the suspension in this was just your standard king spring and reset leaf deal, installed 90/10 shocks for the run to lift front a bit more...
CAR: 1200 ute
WEIGHT: 840kg
MOTOR: A12 @ 104kwatw
GEAR BOX: 56 series 4 speed
CLUTCH: xedy heavy duty
DIFF: H165 (stock)
TURBO/SUPER CHARGER/CARBY: IHI vj26 turbo, a14 efi.
EXHAUST: frankthedolphintrainer manifold into 2.5 inch mandrel.
1/4 MILE: 13.2sec
Posted on: 2011/12/1 21:21
Yes, that's good. 1850 pounds and 139 rwhp -- anything under 13.8 is very good. It doesn't take a lot for the suspension to be set up well for drag racing.
Posted on: 2011/12/2 1:15
turbo torque there rugger box still 56a :)
Posted on: 2011/12/2 1:22
Ruredi,
Here is the ca18 sohc 8v Naps w/ the same features as the Z but smaller valves, ports and bores. Its a turbo ca18et thats putting out 443nm / 258kw atw @ 5500rpm using stock cam and done again by a Finnish dude.
He went aftermarket rods as prepped Det rods would be just a small saving. Stock mid throttle inlet manifold is restrictive compared to the later one. Head is stock also.
Not bad for Nappy head that I agree are crap if cast in australia like most ca20 are.
http://www.dnsf.org/forum/index.php?topic=32062.120
http://www.dnsf.org/forum/index.php?topic=32062.0
Posted on: 2011/12/7 0:39
Car unfortunately had to be sold.
The family problem that caused me to advertise it last time had resurfaced and I didnt have much choice. It's a sad day...
Posted on: 2011/12/8 22:02
So it's gone now- hope new owner joins up to show progress
Good luck with it all
Posted on: 2011/12/8 22:14
Wow.
Posted on: 2011/12/9 1:41
From Melbourne Vic
after all that! ha
Posted on: 2011/12/9 1:43
CA18DET 1200 lagwagon retired
LAG510 - SR20DET 1600 sedan
1000 wagon daily - A series magic
Yeah! Haha
Good luck with the family thing ruredi. All the best.
Posted on: 2011/12/9 1:45
From Melbourne,Australia
Sad day when you have to sell all the best for the future but. I hope the new owner looks after it and keeps the A15
Posted on: 2011/12/9 2:33
