what strut tops to lower 120Y?
From Brisbane, Australia
Its been too long since I played around with Datsuns and I've forgotten what strut tops to use to lower the 120Y front a bit... when I had my 120Ys I had so many different struts lying around I can't be sure which bits I used anymore. I think it was Stanza tops? Can anyone confirm???
Posted on: 2011/12/12 1:47
Re: what strut tops to lower 120Y?
From gold coast aus
interested also
Posted on: 2011/12/12 3:28
starting to think I may have cut the 120Y's strut tower centre hole out to fit the Stanza tops...
Posted on: 2011/12/12 6:21
From Melbourne, Australia
that sounds more likely as the 120y strut tops mount flush with the top of the strut tower, but 1200 and stanza strut tops (same except diameter of mounting studs) reach through the top of the strut tower and mount at least the top of the shock nearly two inches higher (not sure on difference of top of spring height which is the critical measure)
Posted on: 2011/12/12 6:23
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From Christchurch NZ
I've seen it done with 1200 tops. We got bugger all (As in almpost none) stanza's here. Although I believe there's a bit of trimming required.
Posted on: 2011/12/12 6:49
Forced Induction!
Posted on: 2011/12/12 7:14
