« 1 (2) 3 4 5 »
Re: 10 Second A series
yea i remember that thread to chris, old mate said he was pretty secretive about his setup i think. be good to get some info on it
Posted on: 2011/12/30 8:46
www.datsun1000.com
Current Dato -
68 B20 ute
Previous Datos -
ca18det 1200 ute 180rwkw
Stocko 1200 wagon
Sounds like he's definitely winning on the development front. He's getting faster and faster. Here is the last thread.
Posted on: 2011/12/30 23:45
Has to be an intercooler with 35 psi boost ?
micks motorsport dyno tuning the a15 turbo on e85 fuel before it ran 10.7 @ 125mph
http://www.youtube.com/v/-1hyZmC2i_Y
Posted on: 2011/12/31 1:25
just looks like that j pipe be interesting to know why he hasn't gone with an intercooler, thought it might be water to air type but doesn't look like it. i've seen a similar setup in a mates eh holden, had some rare injection just running a j pipe but he's got no clue he bought it like it is
Posted on: 2011/12/31 1:35
www.datsun1000.com
Current Dato -
68 B20 ute
Previous Datos -
Stocko 1200 wagon
Without an intercooler, you'd have to lower the CR of the engine substantially. Maybe he's using water injection to help keep it cool.
Posted on: 2011/12/31 1:37
As stated it's running E85 with meth injection.. hence the no intercooler
Posted on: 2011/12/31 2:07
fair enough, my bad dont know much about e85 must be good #OOPS#
Posted on: 2011/12/31 2:09
www.datsun1000.com
Current Dato -
68 B20 ute
Previous Datos -
Stocko 1200 wagon
E85 is 85% corn alcohol and 15% gasoline.
It is less powerful than straight gasoline, hence you need a rejetted carb, and even so MPG goes down and larger tank needed to go as many miles, potentially with retrofitting you might need larger fuel lines. It's corrosive, so a properly sealed tank is desirable and special type of rubber lines and carburetor parts are needed.
But it has one advantage and that is the alcohol has a cooling effect, so it is said that under boost it acts like 110 racing gasoline.
110 racing gasoline is preferable to E85, but E85 is cheaper. For a non-boosted engine, regular PULP (premium gasoline) is better in almost every way than E85.
Posted on: 2011/12/31 5:13
""As stated it's running E85 with meth injection.. hence the no intercooler""
where was statement made of using Meth? I missed it
I was only guessing perhaps meth is used but can`t see it
Posted on: 2011/12/31 5:36
From Ballarat Victoria
In Aus, most of the E85 is made using alcohol from sugar cane rather than corn.
I presume the end result is very similar.
Pound for pound there is less energy in E85, but because you have to run about 28% more of it to get the same Lambda reading compared to PULP, the energy produced is slightly higher than the unleaded.
A few tuners i know that have changed to E85 in NA engines still report a 5-7% increase in torque over premium unleaded.
Im using it in my turbo A12, but im yet to do any back to back testing in NA engines.
Posted on: 2011/12/31 5:51
VIC DYNO HIRE
« 1 (2) 3 4 5 »
