Hi all,
I thought I might share my progress on building my Coupe into a dedicated 3J circuit racing car.
Some specs of the final car.
CA18DET, E85, Restricted (36mm), forged and a lot of engine work
Motec M84 ECU, CDL3 dash
Standard CA 5 speed
Hilux 3.5 LSD diff
Custom Bilsteins all round.
S4 RX7 front callipers on 294mm disc
Starion ventilated rears
Velo apex II racing seat
Wilwood pedal box with brake bias adjustment
Flares, bobtail and splitter (As you know I am getting moulds made of all these parts).
Colour will be BRE style, white lower half, interior and engine bay (whould make repairs easier). Ford blueprint top.
The body was no show body when I started to strip it. I have replaced both LH and RH sills (Spliced in ute sill's), passenger side rear quarter has had a tough life and has previously been replaced (poorly). I have done my best to straighten it and there is a little skim of bog to get it reasonable smooth. The front driver side inner front wheel guard was smashed in, which I have repaired and replaced the radiator support panel. Firewall has most of the holes closed in (quite poorly by me I must add). I have cut and welded both rear wheel arches to accommodate the lowered, wider track. The seat was a bugger to fit and you can see the mods I have done to get it to sit nice and low in the car. trans tunnel was repaired and "Massaged" to give more room for the CA gearbox.
I like to attempt to do the work myself. So far the car has only left the garage to have the roll cage installed (I won't compromise on safety, after all it is my neck on the line).
Anyway here are a few pics.
Body kit
Back from the cage builder
More stripping
Looking back at the cage and seat
A bit of work on the drivers sill
Stone guard inner wheel arches and under car
Now for some paint. There is no clear on it yet, I am expecting the paint job to be a 20/20 paint job. i.e look good from 20mtrs @ 20km/h. This is a bit better then a 50/50 paint job :)
