« 1 2 3 (4) 5 6 7 ... 9 »
Re: 1200Rallycar - The rally car
From Melbourne, Australia
yep, last car there, they were packing up... just made it
Posted on: 2011/5/12 7:24
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Well i had an interesting event
finished 9th outright and beat the other guy in my class, so pretty happy with result
the front pin on the upper leaf shackle (passenger side) busted somewhere on the second stage, we didnt really know that had happened but we knew the tyre was rubbing on the back of the wheel well, and the back brakes were jamming on
it was two and a half stages (20km each) that we continued like this until service, at service we found the broken shackle pin, and in desperation this was our best solution
swapped the back pin to the front and put a screwdriver through the other , and after frantic searching and whacking at the screwdriver we couldn't bend it, light bulb moment - put a hose clamp on it, then a bunch of race tape. We realised the brake problem was that with the diff moving back this was pulling the handbrake cable on... so that got disconneted at service too
race two more stages flat out like this, worked a treat, and made up a bunch of time. new suspension was great when i got the chance to test it out, though a bung spot light stage 5 (first of two night stages)restricted right hand turns... we had a big off at high speed as i never saw the corner until too late, car got airborne and nearly rolled. Navigator still has a sore neck from that.
so yeah, lots of adventure for us, looking forward to a straight forward race next time hopefully
no pics yet but some vid:
http://www.youtube.com/watch?v=_lS3lLiy_3A
im car 60, after three 1600s come through, i came in a bit hot and held the handbrake for a bit longer than i would have liked to wash off some speed
Posted on: 2011/5/17 11:32
1200 Coupe Rallycar
At least u used a good screwdriver :)
Posted on: 2011/5/17 12:01
Car free
From USA
The video was great. Nice to see a B series Datsun being rallied. What are you using for rear end? Is it the stock diff welded?
Mike
Posted on: 2011/6/5 4:04
Where did you get that rally bar? Or is it homemade?
Posted on: 2012/1/2 4:01
Rear end is a h165 phantom grip/ sprung load locker!
Posted on: 2012/1/2 4:40
Car free
The light bars custom made
Posted on: 2012/1/2 4:44
Car free
Good vid mik. I like the old cars in the field going hard. Top work and keep posting your results
Ooooops @ 6.22 mins
:) Top work
http://www.youtube.com/watch?v=H6ZJJ4vWGxQ&feature=related
Posted on: 2012/1/2 4:54
For a cheap car these datos can get super expensive....!
All the bits for my ute have been acquired, I only need time and a panel beater/painter! Anyone able to help
I guess I better make my own. I love the way this car is used. Do you plan on any power mods?
Posted on: 2012/1/2 5:46
supafatto answered most of your questions, not really panning much for the car except building a carport to protect it and then tidying up the shell a bit
i have a efi hardware quad throttle body setup to suit but havent bothered to use it, i dont really want to spend the money on engine management and fuel system, and i am not particularly hungry for more power as im not prepared to spend the time and money to be competitive outright and am happy with how competitive the car has been in it's class
it does have an a14 bottom end and oval port head with larger valves installed, elec dizzy, extractors,thermo fans, just the usual stuff, definately the limitation would be in using the GX SU style setup for carburation
Posted on: 2012/1/2 6:30
1200 Coupe Rallycar
