Custom Made Head Gasket A15 stroked.
From Sydney, NSW
hi guys,
was wondering if anyone knew where i could get a head gasket made for my stroked a15,
need it to be as strong as possible.cheers,
Dion.
Posted on: 2012/1/6 9:57
Snapped crank and still smiling, How do I do it? LOL
Re: Custom Made Head Gasket A15 stroked.
Stock gasket will hold up to a stroked A15. Prep & torque carefully.
For a high-boost A-series, use a custom Copper gasket from Cometic.
Posted on: 2012/1/6 10:17
From sydney.nsw
PM SENT;
Posted on: 2012/1/6 10:41
A.T.E RACE ENGINES: ( " AUST 1 " 2010 ) A15 GO THE DATTOS... 0412 864 741
Stock graphlex stainless and graphite gasket work well
Posted on: 2012/1/6 12:13
From Sydney, NSW
see the problem is that the pistons are oversized so wont the gasket need to have bigger piston holes on it??
Posted on: 2012/1/6 23:42
Ah, you mean a bored A15. The Nismo gasket is oversized and works with 79 mm pistons. I have 78.5 pistons in my A14 which give it more CCs than a stock A15. With 79s you'll be over 1600 i think.
Posted on: 2012/1/7 0:01
From Sydney, NSW
its been bored out to 1650cc, so will they fit? an di need to hold as much rpm as possible
Posted on: 2012/1/7 5:08
Stock A15 stroke with 80mm pistons is 1649cc. The Nismo gasket handles high RPMs no problem (8500 rpm).
The Nismo gasket is 79mm
Bprojects Australia sells a 80.5 gasket.
You might ask Bige what he recommends.
Posted on: 2012/1/7 6:50
From Sydney, NSW
ahh ok, thanks for that :) when it comes to stroke and all this i am just so confused, ill definitely give it a look, and bige what do you recommend, i want it to handle 10 0000 preferably .
Posted on: 2012/1/7 7:15
From Sydney, NSW
Decided to head down to Obriens Aluminum in Windsor, using my warped head gasket get them to make me one out of copper, my mechanic suggests that its my best bet as only the 2 centre holes in the gasket are warped and the outer 2 are just fine.Cheers guys!
Dion
Posted on: 2012/1/8 13:59
