Electronic ignition - points replacement, info needed.
From Brisbane
A mate of mine is looking to replace his points set up in the stock distributor in his rally car.
Has anyone used the
http://www.hot-spark.com/1-Hitachi-Distributors.htm
or the
http://www.ebay.com.au/itm/Pertronix- ... ories&hash=item3370050092
can anybody recommend a realable product for him, or does anyone have one they don't want anymore.
Ta.
Posted on: 2012/1/9 9:01
Re: Electronic ignition - points replacement, info needed.
petronix has been used by a fair ppl on this site and are easy to setup as the are just a magnito setup
Posted on: 2012/1/9 9:50
Car free
From Adelaide, Australia
I put in the petronix a couple of months ago, good as gold so far
Posted on: 2012/1/9 10:42
1200 ute money pit
From Perth WA AUS
The hot spark kit works well for me :)
Posted on: 2012/1/9 12:08
Datsun 1200 2Dr sedan.
From Sydney, NSW
i used the crane cams xr3000, produces a high spark and works terrific.
Posted on: 2012/1/9 21:56
Snapped crank and still smiling, How do I do it? LOL
Crane XR3000 and XR700 work well, but are external modules. You can buy them in Kit form with an included optical trigger and trigger installation kit.
By comparison both Pertronix and Hotspark fit inside the distributor and are internal modules that replace the points.
* for a 'cleaner' 2-wire install: Pertronix or Hotspark
* for a 'cooler' look of anodized aluminum module mounted on your inner fender or firewall: Crane XR700 or XR3000
The Crane Ignition XR3000 is higher performing than many EI units.
Posted on: 2012/1/9 23:23
Edited by ddgonzal on 2012/1/9 23:58:33
Edited by ddgonzal on 2012/1/9 23:58:48
Quite a regular
From Brisbane
Hi everyone,
I am in the process of changing my ignition system from points to electronic. I have an A14 in a datsun B310 rally car.
I am deciding between running the Crane Cams XR3000 or installing an E15 electronic distributor from a N12 Pulsar.
My concern with the external module on the XR3000 is that it will constantly be covered in dust, mud, water etc and be jolted around in the rally car. Given that the module represents 75% of the purchase price it would be an expensive exercise to replace if something went wrong. Hence I am leaning towards the E15
The current points distributor I have in the car is what I believe to be a hitachi out of a B210. Code on the distributor is D411 – A3 0401 matched with a GT40 Coil.
I have a spare distributor which I think is either a series 2 bluebird or an E15 from a N12 pulsar.
The code on the dizzy is D4R – 83 – 39 22100 P4000 5805 – Can anyone tell me what I have got?
It is attached to the side of an A15. See pics attached.
Will the reliability and spark performance be better with the E15 or the XR3000?
Can anyone identify the dizzy from the code and photos?
Will that dizzy attached to the A15 bolt straight onto the A14 or will there be an issue with gear changeover?
Can anyone provide any recommendations, comments or alternate options on the above.
Thanks for your help
Cheers,
John.
jpg  dizzy 1.JPG (114.99 KB)
16145_4f0d52e9bb603.jpg 640X478 px
jpg  dizzy 2.JPG (101.44 KB)
16145_4f0d52fca7a13.jpg 640X478 px
Posted on: 2012/1/11 9:16
The E15 distributor is super reliable and can drive hot coils. Both are better than a points setup, both are high energy. The XR3000 is better at spark, but how much do you really need? Because you can buy a CDI setup that's better than the XR3000.
22100-P4000 is in the Datsun1200.com tech wiki: 22100-P4000
Yes, any distributor that works in an A15 will work in the A14, straight bolt in.
By the way, a GT40 coil is a low-energy coil. If you go with the 22100-P4000, just fit a coil from Pulsar or Bluebird, it a lot hotter. See EI Coil.
Posted on: 2012/1/11 10:16
Quite a regular
From Brisbane
Thanks for the reply.
I have read the tech wiki entry regarding coils so I can only assume that a MSD Blaster 2 coil coupled with the E15 would suffice?
Cheers,
Posted on: 2012/1/11 10:40
I do not know if that will work. I recommend the Bluebird Series II or Pulsar N12 coil. Only a few bucks at the wreckers, or buy them new at Nissan.
Posted on: 2012/1/11 20:16
