B210 / 120Y Coupe Wrecking in Perth
Quite a regular
Hi all,
I have a complete 120Y manual coupe wrecking. All panels and body are RS.
Everything else seems to be there. All glass is good and some trim.
Let me know if there is anything you are looking for...
Adam
Posted on: 2012/1/7 12:43
Re: B210 / 120Y Coupe Wrecking in Perth
From mandurah
ill take the front sway bar ,name your price
pm sent
Posted on: 2012/1/7 13:03
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
I'll take any interior trims if they are any good.
PMed
Posted on: 2012/1/7 22:49
From Perth
What diffs in it ?
Posted on: 2012/1/8 2:00
Quite a regular
Good question...
ID plates gone so no numbers.
It has 8 Bolts holding it to the housing so I think it is a H150 if I'm reading Wiki correctly...
As for ratio?? Dunno, it is a 4 speed A12 if that helps..
Adam
Posted on: 2012/1/8 3:37
Quite a regular
From Bendigo
I am looking for a good standard A12 block, what condition is yours? Cheers Peter
Posted on: 2012/1/9 12:08
Quite a regular
Good, but I'm in Perth...
Long way just for a block..
Posted on: 2012/1/9 21:19
Not too shy to talk
From Perth WA
Hi mate am after left front door handle and linkages if you have? And maybe some other interior bits and pieces?
Posted on: 2012/7/18 0:38
I'm interested in castor arms
Posted on: 2012/7/18 2:23
Car free
