speedo troubles in ca18de ???? any suggestions
From brisbane
the speedo in my new wagon is jumping around all over the place and sometimes not at all.... anyone had trouble with this before , and whats the most likely cause. could it be the sensor on the gearbox and more likely the actua gauge in the cluster??????? ?????
Posted on: 2012/1/27 7:42
A15 1200 ute, 77 mini -b16a honda vtec project
Re: speedo troubles in ca18de ???? any suggestions
From Logan, QLD
sounds more like the wiring or connection before anything, check the thing is connected properly at the gearbox end.
Posted on: 2012/1/27 7:46
From MOOROODUC. Victoria
Similar problem ..... unsolved.
check that everything is earthed that needs to be.
I assume you are using the electronic speedo from the S13?
Posted on: 2012/1/27 7:53
From brisbane
yeah i'm using the s13 cluster. my old ca18det ute did the same thing but not as bad. sometimes it will sit on 20 or 40 when accelerating or decelerating. just sits there and won't go up or down so thats why i was thinking not an earth... it doesn't always jump around sometimes it just won't move . if i was to use another mechanical speedo what sender or sensor thingy should i use, or cable etc. ????????
Posted on: 2012/1/27 7:58
