BEST COMPUTER FOR CA18DET
From Chipping norton sydney
Iam finally up to the process of buying a computer for my cadet conversion into my 1200 ute n Im in tossing up between the microtec lt10s and a stinger ecu watt do people prefur to use cheers
Posted on: 2012/1/29 10:01
Re: BEST COMPUTER FOR CA18DET
I have a few mates with stinger's in there race cars (xr6, ba, vt) with data log and dash displays and all they want from the cars and stinger aint failed them yet. The m8 who does all the looms and tech side of it from this team has said to me stinger is easy to set up maps and adjust mixtures even while there out there racing via a knob. I aint to shore about microtech but that is what do know
Posted on: 2012/1/29 10:18
For a cheap car these datos can get super expensive....!
All the bits for my ute have been acquired, I only need time and a panel beater/painter! Anyone able to help
From brisbane
What features/functions do you want? That will help people make recommendations.
I have used a Nistune ECU for the past few years and have been very happy with it.
My brother and several other people I know are using the lastest Haltech Platinum series ECUs with excellent results.
Posted on: 2012/1/29 21:12
1985 CA18DET Datsun 1200 ute
1969 A12 Datsun 1000 coupe
From Canberra
I currently have a Microtech LT10s tuned for a CA that I might be happy to part with for the right price. But ill try to make this unbiased :)
These are at the very cheap end of the ECU market.
They are very good at wide open throttle but really do lack some refinement with compensation tables that others have.
The idle control could be better also, works reasonably well but is not as smooth as others. I find the PWM ciontrol in these ECUs hunts a bit with my CA, you could probably fiddle with it to get it better but i have spend many hours to get it this good.
After sales support is almost non existant with Microtech. My understanding is the re-seller in newcastle handles most of the repair/reconfig work on behalf of the company.
I am upgrading to a Motec M84 (Race car), I am looking to add a lot of sensors to the car for logging purposes and need the extra inputs and CAN communications.
Overall, I did not have any issues with the microtech in a street car. The engine made very nice power 330rwhp @22psi and was fine on the street.
With any of these ECUs they really are only as good as the tuner tuning them. My recomendations is to pick a tuner first and work with them on the ECU solution.
Posted on: 2012/1/29 21:30
Isn't the best computer an S14 automatic ECU? For stock engines, no tuning needed.
For highly modded engine maybe with different type of injectors, etc. people here favor the MegaSquirt. If you like specification sheets, the new 32-bit is nice but otherwise the older one makes the same horsepower with less bragging rights.
The microtec and stinger are both great products and certainly you are worth the price they charge for getting advise from the manufacturer. The do-it-yourself route doesn't offer that.
I second McGee's advise on checking with the tuner you will be employing.
Posted on: 2012/1/29 21:41
From United State
Thanks for providing such a very informative post. Actually, I was some beat confusing for this same problem regarding computer for CA18DET. Now I'm cleared with this issue.
Posted on: 2012/3/1 11:26
mobile signal boosters
