no compression after rebuild??????
From durban, south africa
hey guys,
i checked my compession over the week end and 2-4 are between 160-170psi but number 1 is 0psi!!!
i have just rebuilt the whole engine and that creeps up on me could i have broken rings? on my ported head i had 90psi but on a stanard A-14 head it shows nothing.
when i put my hand over the ports it does not even suck.
WHAT CAN BE THE PROBLEM NOW?????
I AM READY TO BURN THAT ENGINE VERY SOON
Cheers guys
nicholas
Posted on: 2004/3/14 19:21
VW chassis
fibreglass body
A-14
280 cam
ported head shaved 1.5mm
extractors with 2inch s/s pipe
webber 38 dgas.
to come........
Dellorto 36 drla
turbo
and then maybe some gas
Re: no compression after rebuild??????
Could be valves, or could be piston/rings.
A vacuum test can determine it (instructions come with the vacuum gauge).
You can also put it on TDC for #1, then check if the valves have the correct clearance. If it doesn't that's your problem.
To tell about piston or rings, while (if) engine is running, is it blowing excessive vapor out the breather hose?
Posted on: 2004/3/14 20:34
From Tracy ,Ca
squirt some oil into the cylinders and recheck
if compression increases likely ring problem I have seen some engine rebuilt by others with not enough lube on rings and no compression untill adding oil to cylinders with a broken ring you should still have some compession make sure your valve clearance correct
bob
Posted on: 2004/3/14 21:49
HI NICHOLAS,
HAD A AFRIEND BY THE NAME OF MICHAEL KYRIACOU,HE HAD THE SAME SYMPTOMS AFTE REBUILDING A NIKKI 850 SCRATCHING HIS FOREGHEAD A FEW TOO MAY TIMES HE HAD NOTICED THAT DOWN NEXT TO THE KFC BUCKET IN HIS GARAGE WAS LAYING A ROD AND PISTON IMMEDIATLEY REALISED WHY THE COMPRESSION PROBLEM EXISTED.
HOPE THIS HELPS.
WHAT TIME IS IT ITS DAT TIME AGAIN.
Posted on: 2004/3/15 2:27
From Canada
Zero? Notta? None??
Did you put that piston in?
How bout the valves on that cylinder?
Mayby you over tightened the valves on it and they are open.
Thats just plain wierd
Posted on: 2004/3/15 4:21
From Millgrove Vic OZ
Mudflap,
How about filling in some details on your self?
Posted on: 2004/3/15 10:30
Cheers Feral
From Warwick, QLD
Also please don't use caps lock when typing as it seems like your shouting your post, sorry but I am very anal when it comes to the caps lock key
Thanks mate
Damo
Posted on: 2004/3/15 10:59
Drive It Like You Stole It
Every Car Has 500hp In The Wet
Team NEW SKOOL
From Melbourne, Australia
thats halerious
Posted on: 2004/3/15 12:44
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From Perth Austarlia
remove the intake manifold and have a peak doen the intake of one.
Does the intake valve open when u hand crank the engine?? If it doesn't, take of the rocker cover and check the rocker arm to valve stem clearance.
If that is within specs, check that the push rod ??? is in one piece and has been installed correctly. its possibly to get these stuk when installing the head.
Posted on: 2004/3/15 15:35
