« 1 2 (3) 4 5 »
Re: CA18DE LHD '72 Coupe
That's a common problem. Other fix is a really big hammer
Posted on: 2012/2/8 6:21
the wheel scrubs a little on the footwell
The wheel? What are you runinng 22 inch wheels?
If the tire scrubs, that is a common problem. You can fix it withough cutting/bashing.
Posted on: 2012/2/8 7:12
From Ormeau goldcosst qld
Is that true can u really fix it with a hammer. Can it do more damage then good??
Posted on: 2012/2/8 9:29
1980 datsun 1200 ute ca18det gt28 200hp
1/4 mile 13.357 at 104.52mph
From Las Vegas, NV USA
The wheels are 15x7 with a zero offset. I have 310 lower arms and struts. Everything seemed to work fine with the stock suspension, but once I put on the 310 bits the wheel scrubs "when turning" on the footwell. I should have clarified that point, I'm sorry. In the straight and with gentle turning there is no scrub at all, but there is definitely scrub in a heavy turn near full lock.
I think I'm going to go ahead and modify the footwell the small bit to fit the tire size, but I'll avoid the hammer as the car deserves a bit of class
Posted on: 2012/2/8 18:01
There is a better solution ...
Posted on: 2012/2/9 3:12
So I had a pair of leather seats donated to me from an Acura TL. They are fully power, and black leather with a breathable leather center section. I think those will make the car pretty awesome, so I'll be seeing how I can fit them in.
Here's some progress so far. Right now I'm starting to see the basics of what image I've been going for and I'm excited.
Posted on: 2012/2/9 7:50
Bodywork continues. It seems absurd how so many people in the US don't even know what this car is. And even then, I'm going to make it harder by removing some of the trim badging. Most of the stuff on the car was OK, but I decided to not put on the center rear badge and the trunklid "datsun 1200" badge. I welded up the mounting holes this evening. I also welded shut the old holes for the mirror and the two locations for the radio antenna. For my radio antenna I'll do something a bit more concealed. I also fixed the tire rub problem and that won't even pose an issue now.
I got the fenders and apron mocked up in position on the car to see how much flare I'll need and it looks like I'll be fine with a moderate flare. I will need to cut the fenders a little to make it all work. Not too concerned as both fenders need some serious TLC to get right even to stock.
The leather Acura TL (Honda) seats will work fine too. I got the mounting figured out and it should not require any bastardizing the car.
I'm just in love with the stance of the car though. Can't wait to get past this panel beating phase. I wanna get this done and drive it!
Posted on: 2012/2/12 7:23
So I'm gonna resurrect this thread since I finally got some headway made.
First off; I simplified and changed a lot. The wheel scrub issue was easy: change the offset, so now we fit good.
I also dumped the Acura seats and I'm going to go with the stock seats. Simple reason: they fit better and can still use the back seat.
I guess I just needed to stop and quit getting carried away with what the car needed to be. So, we're keeping all the original lines, and a lot of the original and evenly mixing in some new school cool.
Photobucket is down so pics tomorrow.
Posted on: 2012/9/25 5:43
All Nissan all the time!!!!!!
1991 Nissan Pathfinder VG30E
1982 Datsun 720 King Cab 4x4 Z22ET
1986 Nissan 720 2WD Z24
1972 Datsun LB110 Coupe Soon to be CA18DE
Not too shy to talk
From Perth WA
cool build mate looks good
Posted on: 2012/9/25 9:39
So I promised pictures of progress so far.
The fenders were in sad shape and since they are not easily available here in the US, I took them to bare metal and fixed the dents and metal
I also changed the offset of the front so now the front and back are the same width but different offsets. Tires clear fine with no rubbing and the back looks to be bigger even though the wheels and tires are realy the same size.
Primed front fenders
Whole car primed
http://i1131.photobucket.com/albums/m ... 2kc/bundle06222012102.jpg
So now, the whole car is in high fill primer and ready to block sand. I hope in the next couple weeks to finally get it painted and then I can finally get it running.
Posted on: 2012/9/26 6:53
« 1 2 (3) 4 5 »
