a12 70mm stroke + 76.5mm bore = how much capacity
From Newcastle nsw
hi guys, got a a12 block off a scrappy thats got 76.5mm bore, laser/mazda pistons which have valve reliefs. its standard 70mm stroke but was wondering with that bore size does anyone know what ccs this ends up being??
cheers
Josh
Posted on: 2012/2/17 6:28
Re: a12 70mm stroke + 76.5mm bore = how much capacity
From sydney.nsw
1285.86cc
Posted on: 2012/2/17 6:43
A.T.E RACE ENGINES: ( " AUST 1 " 2010 ) A15 GO THE DATTOS... 0412 864 741
From Wanneroo, Western Australia
I get about 1,287cc.... Pi x Radius (half of bore) squared x depth (stroke) x 4, all divided by 1000.
4( (22/7) x 38.25 x 38.25 x 70)
1000
22/7 is about the closest I know to pi, without having a scientific calculator. Hope this helps!
Posted on: 2012/2/17 7:05
That's a hot find! Basically similar to TS1300 racing motor (if they are flat-top pistons). In NSW, you can owner-certify a 1287cc engine, while an A14 needs engineer certification.
And with the short stroke, it'll really rev. Well so will an A15, but it makes me feel better about my A12 to say that.
Posted on: 2012/2/17 8:04
From Newcastle nsw
Should see the head that came with it. H89 large valves, double springs, bigger ports than the Peter zekert gx head I've got! Scored some front doors, 13 inch hotwires with semi slicks, a coupe dash, 2 1200 ute diffs, few tailshafts, coupe rear bar and a few other random bits. Was all heading to scrap metal!!!!!!
Posted on: 2012/2/17 12:27
From Sydney, Australia
It's a great find. That's for sure.
We've fitted the a14 to several 1200s in the past 20 years without needing an engineers cert in NSW.
Unless something changed in the past couple of months.
Posted on: 2012/2/17 13:20
Id love to find such treasure in a scrap yard
VSI 06 "owner certified":
Engine changes where the capacity is less than 15% above the maximum engine size available for the vehicle
VSI 06 is from November 2007
1171 * 1.15 = 1347
Posted on: 2012/2/17 19:00
