charge light problems
Quite a regular
From gold coast
hey i was wondering if anyone can help me,
i have a charge light problem, i have bought a new regulator and i have had my alternator tested and it came back ok however the charge light still comes on and when i rev it the light shines brighter i have no idea what to do if anyone can help me it would be much appciated
thanks Nick
Posted on: 2012/2/24 21:11
Re: charge light problems
Not too shy to talk
Is your alternator charging properly? Stick a multimeter on the battery whilst the car is running, it should show 13-14v and when off around the 12 mark (or at least a bit lower). If it's charging then the problem lies in the light wiring. Could be connected to the wrong terminal on the alternator? Would have to check a wiring diagram to see how it is wired normally.
Posted on: 2012/2/25 1:26
Not too shy to talk
From Brisbane
I am having a similar problem, light all of a sudden came on.
tested across the battery, getting 14volts
12.5 when off
did you find a solution?
bruce
Posted on: 2012/7/15 8:34
The dash lamp is controlled by the regulator.
13-14V when running above idle is good charging voltage.
Since your voltage is correct, the regulator is probably the culprit.
Posted on: 2012/7/15 19:14
From Stone Age somewhere in U.S.A.
It could also be as simple as a blown fuse.
Posted on: 2012/7/15 22:51
From MOOROODUC. Victoria
or a loose wire.
I had a temp gauge problem that I eliminated at least 6 wild possible causes until I found that the wire was loose
Posted on: 2012/7/15 23:05
How could it be a fuse or loose wire? Wouldn't that cause it not to charge, or not to light up?
Posted on: 2012/7/16 0:14
Not too shy to talk
After a quick look at a 1200 wiring diagram, (assuming most models are wired similair) it would be either the 12v regulator or a wire/plug somewhere shorting the positive wire to the light to another voltage. Being that the light gets brighter with rpm, I would suspect the regulator isnt working. A good regulator shouldnt change much in voltage regardless of rpm, because its "regulating". Measure your battery voltage whilst changing rpm, if its going up and down from around 12-14 volts the regulator isnt doing its job. It may be working as you said, but that means your wiring is wrong and its not working in the vehicle.
Posted on: 2012/7/16 2:59
The chaging system is fused through the fuse box, if blown it will cause dash lights.
Also, has the alternator been changed recently?, I know that it's a remote possability,
but I have seen where an external regulator alternator was replaced with an intenal regulator unit. Easy mistake to make as they do look very similar.
Posted on: 2012/7/16 15:52
