Tailshaft on CA Gearbox
From Mandurah, Western Australia
Got a new tailshaft a fair while ago now
Just bolted it up into the car and I think its too long. There is only about 5mm of yoke sticking out back of box. Tailshaft supplier reckons this will be fine as the gap will increase under load.
But took car for drive and box is getting hot and its pushing oil out through the breater (I think)There are no noises eliminating from the drivetrain and I dont think the box is over filled.
Opinions?
Posted on: 2012/3/5 6:49
Re: Tailshaft on CA Gearbox
From Melbourne, Australia
should have more than 5mm!, under suspension bump (travel up) the shaft will need to push into the box, i think 25mm is considered ample in normal cases
Posted on: 2012/3/5 6:52
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
That was my thoughts
If there is too much yoke in the box, can it rubb in the back of the box or something like that?
Posted on: 2012/3/5 6:59
i think from what im told its most likely to blow the rear seal, but i've never had the problem myself, it must hit/rub something at some point
[edit] actually im sure you can put yoke in all the way, the fillet at the end of the yoke would rub against the rear seal once its in too far... hence blowing seal
Posted on: 2012/3/5 7:02
1200 Coupe Rallycar
From Geelong, Vic
yeah wont hit anything inside the box, will just give the seal a hard time.
tailshaft guy seems smart....cars dont squat under load at all
Posted on: 2012/3/5 23:15
