« 1 2 3 (4) 5 »
Re: Kitchs 1200 Coupe
Get cracking heaps of room in that garage
Posted on: 2012/3/8 10:35
From MOOROODUC. Victoria
Keep going.
You'll find that you think you're not doing much and then things will start to fall in place
Good work
Posted on: 2012/3/8 21:54
From Sydney
Looking good, those wheels look great. Where did you get the rabbit inserts from?
Cheers
Posted on: 2012/3/9 23:36
the VW inserts, are Monroe's that I got from the local shock shop
Posted on: 2012/3/10 3:51
Long overdue update.
Got the Fuel feed system all finished, manifold all welded up.
Megasquirt installed, and wired up, with relays & fuses etc.
Vacuum manifold all plumbed in etc. hooked up basic inputs like
TPS, VR Sensor & injectors etc (O2, temp, and ECU driven spark
will come on line down the track) have done fuel flow tests etc.
Fired it up at weekend, but couldnt get it to run at all.
Played round with some fuel setting before corrupting all my
firmware code I think. so ended up spending a few hours
reflashing the ECU code, and uploading new tuner studio
software and the likes. got it all communicating again, and
it fired up again, before I flattened the battery.
I charged up the battery overnight, and tonight I hooked up
temp exhaust system tonight and got it semi running
(have a few more issues to work through, before i even
attempt to tune)
Start up video below, for those interested.
http://youtu.be/oCgWkJbDs2U
Want to get it running a bit better, before I
pull the motor and running gear out to get the
engine bay painted.
jpg  engine new small2.JPG (29.94 KB)
9374_4fc48b177bba6.jpg 448X336 px
jpg  engine new small.JPG (30.71 KB)
9374_4fc48b2678101.jpg 448X336 px
jpg  manifold small.JPG (30.83 KB)
9374_4fc48be94b307.jpg 448X336 px
Posted on: 2012/5/29 10:01
From Melbourne, Australia
sexy!
Posted on: 2012/5/29 12:56
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Love the gaffs tape ecu laptop tuning device lol.
Looks great- should be more fun than webbers etc.
Posted on: 2012/5/29 13:33
Righto, long overdue update....
Yes I have been still working on my 1200 coupe.
Its very close now (90% finished I guess), this is what I have completed in last year, since I last updated this thread:......
- Panel work completed (just doors require a tidy up)
- Engine bay all painted (original factory red)
- Suspension & brakes all installed and finished
- Comprehensive sound deadening fitted through interior
- Wiring all completed throughout, and ECU & fuses mounted
- Alloy radiator, electric fan and all new silicon hoses fitted
- New motor fitted (high compression balanced A14)
- Reconditioned 5 Speed and custom X member fitted
- New Surge tank setup installed (underbody IE type)
- New Fuel lines, Bosch feed pump & facet lift pump
- A lot of NOS parts fitted throughout
- Custom Panhard rod fitted up
Pictures speak a thousand words, so here we go:......
jpg  001.JPG (164.76 KB)
9374_51f4d0cd2efa0.jpg 772X579 px
jpg  002.JPG (126.43 KB)
9374_51f4d0ddede03.jpg 858X644 px
jpg  003.JPG (160.67 KB)
9374_51f4d0f791751.jpg 772X579 px
jpg  004.JPG (167.87 KB)
9374_51f4d108829a3.jpg 772X579 px
jpg  005.JPG (176.66 KB)
9374_51f4d1171ecd3.jpg 799X599 px
jpg  006.JPG (172.50 KB)
9374_51f4d12b100ef.jpg 772X579 px
jpg  007.JPG (161.07 KB)
9374_51f4d14ab7eab.jpg 772X579 px
jpg  008.JPG (167.60 KB)
9374_51f4d1646bd4e.jpg 772X579 px
jpg  009.JPG (156.04 KB)
9374_51f4d176e8302.jpg 772X579 px
jpg  010.JPG (199.15 KB)
9374_51f4d193cf507.jpg 772X579 px
jpg  011.JPG (179.59 KB)
9374_51f4d1add2387.jpg 764X573 px
jpg  012.JPG (191.32 KB)
9374_51f4d1d2656b5.jpg 772X579 px
Posted on: 2013/7/28 9:15
After a few teething problems last week, I have managed to get it running today.
So stoked for it to finally make some music!
My EFI / ITB dream, has taken a huge amount of time & $ to bring to reality.
From seeing a V8 Lexus motor on youtube about 5 years ago, I decided to go
EFI / ITB A series on my coupe. At times I was over it, and was ready to throw it away, but I am glad I have stuck with it. I am pretty proud to finally get it running....
Be interesting to see what sort of HP it is putting out, once it is all tuned and sorted.
It is running in a base tune only, which is very rich. And my default ignition maps will need some work (running wasted spark setup, with coils driven by onboard drivers in the megasquirt ECU)
Here is a youtube link of it making some noise this afternoon:
http://www.youtube.com/watch?v=WXLymsjttoA&feature=youtu.be
Here is a link for a quick walk-around
http://www.youtube.com/watch?v=ujueMCih-GY&feature=youtu.be
Posted on: 2013/7/28 9:21
Edited by KitchNZ on 2013/7/28 9:54:12
wow.
absolutely amazing!
Posted on: 2013/7/28 9:30
« 1 2 3 (4) 5 »
