Sr 20 turbo manifold query
From Sydney
Hi guys this is not 1200 related but I want to know how important the divider is in a factory cast iron sr20 turbo manifold. I'm upgrading the turbo in a pulsar Gtir and have found a hair line crack in the divider. I don't want to put it back in because I'm afraid in may come off and damage the turbo. I'm thinking I can cut it out. Has any one done this before.
http://i1258.photobucket.com/albums/ii525/DJF280/9846b17b.jpg
It's hard to see but it's cracked to the left and right where the divider is cut down the middle ( cracks start where the cut stops)
Posted on: 2012/3/11 10:59
Edited by DJF280 on 2012/3/11 11:19:00
Re: Sr 20 turbo manifold query
is it a twin pulse manifold? what turbo you upgrading to?
Posted on: 2012/3/11 11:18
www.datsun1000.com
Current Dato -
68 B20 ute
Previous Datos -
ca18det 1200 ute 180rwkw
Stocko 1200 wagon
From Sydney
Not sure what a twin pulse manifold is. I just put a link up of the manifold. I went to a gt2871r with Gtir high flowed comp cover so everything will fit neatly like factory
Posted on: 2012/3/11 11:23
its actually split pulse sorry my bad, but yea thats what it looks like. does your turbo have a twin scroll turbine housing?
Posted on: 2012/3/11 11:36
Edited by lethal_john on 2012/3/11 20:01:51
www.datsun1000.com
Current Dato -
68 B20 ute
Previous Datos -
Stocko 1200 wagon
From Sydney
I thought that's what u ment. No the turbine housing is just open like any other Garrett t25/t28 turbo. My idea is to cut it out just to cracked part not a quick job by the look of it
Posted on: 2012/3/11 12:02
tell you the truth never looked down a standard sr manifold lol but it's the same on my sil go figure so turbine housing is not relevant, i dont think it will break i've never heard of that happening and you'd have to be unlucky. the time your gonna waste grinding that out you might as well buy another standard manifold (50 bucks) or get an after market one, as for it being relevant im not 100 percent sure but it's gonna be a biarch to get out
Posted on: 2012/3/11 20:13
www.datsun1000.com
Current Dato -
68 B20 ute
Previous Datos -
Stocko 1200 wagon
From Sydney, Australia
I'm with lethaljohn. If you might have to pay someone else to fix it, it would be cheaper to pay $50-$150 for another stock manifold. Especially if you are putting a nice shiny turbo behind it.
I've never heard of these failing either.. So you'd have to be pretty unlucky for the crack to progress to a chunk falling off.
Posted on: 2012/3/11 21:16
From Sydney
Iv spent about 4 hours making the ports smooth and cleaning the sharp edges on that manifold, going to try cut it out with a small air grinder if it don't work I'll bin it and get another and hopefully it won't be cracked in the same spot. I'm going to stay away from cheap stainless steel manifolds. Not planing on doing this job again! Anyone that has worked on a pulsar Gtir would know what I'm talking about
Posted on: 2012/3/12 13:13
From sydney
more work on the 1200..less on the gtir;)
Posted on: 2012/3/12 13:31
datto 1200 ute a12..low n slow (SOLD)
datto 1200 ute, a15 (SOLD)
fj20 1600 (SOLD)
CURRENT: 1200 Coop SR20de project Sleepin
From Sydney
Louix the yellow coupe has been pushed outside now, it kills me to see it sitting out there. After 2 hours of carefully cutting with air hack saw and air grinder I managed to get it out. Now it just needs a clean up. The big question is it going to work better or worse, looks less restrictive but will flow be interrupted due to half the devider missing?
http://i1258.photobucket.com/albums/ii525/DJF280/7bd68d2a.jpg
Posted on: 2012/3/13 11:19
Edited by DJF280 on 2012/3/13 11:39:59
