spot welds
From Goulburn NSW
Hi guys just curious iff u unpick a spot weld how do u reweld it iff u dont have a spot welder
Posted on: 2012/4/14 9:25
Re: spot welds
you can plug weld. I looked into getting a spot welder, not really worth it if you're not going to be doing alot (might be worth fitting the gaurds preping them and taking the car somewhere to get someone to just do the spot welds?), i took both rear quarters off of my ute and just plug welded them all back on, ground em off with the 100mm grinder when i was done. came up a treat. if the grinds dont come up perfect you can always slap a very light coat of bog along to get that ultra smoothness i guess....
Posted on: 2012/4/14 9:40
1200 Ute - Mild A12
1200 Ute - Donor Shell Sold
1200 Coupe - A14 EFI SC
Re: spot welds
Upol strong hold panel adhesive... Do some research on this stuff. I used the 60 minute glue on both my rear quarters and sills... It's a 2 part panel glue with glass beads in it so it doesn't all squeez out when clamped in position.. No welding no warping no grinding.... Perfecto! This stuff is quit expensive and most of the new cars are out together with this stuff these days... Was about $80 for 200ml and $40 for the gun which did one silk and rear quarter plus I had some extra left over..,
Posted on: 2012/4/14 10:48
Re: spot welds
From Malaysia
did you mean you used Araldite™ epoxy?
Posted on: 2012/4/14 14:44
Re: spot welds
Yeh man of course did you read it? I used UPOL..... 60 minute weld bond adhesive.,.. Take a look at a new car and see how much of its actually glued together... U will be surprised ;) I was told by my panel beater that he would be using panel adhesive to glue the new panels on..., so I did it myself
Posted on: 2012/4/14 23:14
Re: spot welds
From Malaysia
advertisement guy glued a cortina to a billboard to show its strength. and then they glued another cortina on top of that cortina. so gluing panel is trivial matter...
that is London in '83
source http://en.wikipedia.org/wiki/Araldite
Posted on: 2012/4/15 6:56
Re: spot welds
From Malaysia
now i realised the upol hahahahaha. read it, but not the first word.
Posted on: 2012/4/15 7:04
Re: spot welds
This worked for my bro in laws Baja VW beetle, waterproof, resistant to shock, temperatures and glued frp to metal.
http://www.selleys.com.au/trade/build ... -nails-mirror-metal-glass
Posted on: 2012/4/15 10:18
Re: spot welds
Hyundai have been glueing their firewalls and roofs on for years
Posted on: 2012/4/16 6:07
Re: spot welds
From Sydney
Airbus is glued lots of planes to, so it would wanna work.
Posted on: 2012/4/16 10:02
