1200 ute front suspension
From brisbane, QLD
Hi guys
So I'm interested to see what suspension and strut combination that i can use in my 1983 1200 ute and people's thoughts on which are the best way to go.. Im trying to figure out a good upgrade for my ute with a bit of both worlds being good performance and ride quality..
It currently has 120y struts and s13 brakes but looking for a bit more Performace I guess
All help is appreciated
Thanks
Posted on: 2012/4/19 15:45
Clint at Profile Autosports and tuning for all mechanical needs and dyno tuning Brisbane..
current rides..
02 hilux daily.
ca18det 1200 ute
Re: 1200 ute front suspension
Cannot beat a set of Koni's. Not cheap but lifetime warranty and they will rebuild them for you whenever. Great shocks.
Posted on: 2012/4/20 0:44
1200 Ute - Mild A12
1200 Ute - Rolling Shell Donor
1200 Coupe - A14 EFI SC
From Albury
and some 250 pound springs a 120y sway bar and a bit of camber and you are there
Bob
Posted on: 2012/4/20 7:43
From windsor, sydney
if you want a high performance option check out the S15 shock and spindle, R32 skyline disc and 4 spot caliper combo i have on a ute, there is a lot of this stuff around and lots of shock / spring options available
jpg  31052011440.jpg (41.21 KB)
9512_4f912880f3fe6.jpg 480X640 px
jpg  31052011438.jpg (42.63 KB)
9512_4f9128ce879fc.jpg 480X640 px
Posted on: 2012/4/20 10:12
WARDMAN ENGINEERING
CNC machining
Race Car Fabrication
Suspension, Brake, Drivetrain modification
TIG welding of all metals
0413 595 627
Soooo much want.
what sort of master cylinder/booster combo would you need to run those brakes though?
Posted on: 2012/4/20 10:55
From Boredomville Melbourne
After a run in anges ute I'm not sure why you needmore!
Also tomos n14 4 spot sumitomo combo was pretty impressive.
Posted on: 2012/4/20 10:57
Was B110 Sedan: L series and 5 speeds, the way they should have been
Now A10 Stanza: L series and 5 speeds...
yes unfimilia that is the same sumotomo caliper
Posted on: 2012/4/23 2:15
WARDMAN ENGINEERING
CNC machining
0413 595 627
Yours run vented or non vented disks. Theres 2 kinds of 4 spots
Posted on: 2012/4/23 3:16
mine are vented 305mm dia r32 skyline rotors and the matching 4spots
Posted on: 2012/4/23 23:57
WARDMAN ENGINEERING
CNC machining
0413 595 627
