Stud Pattern Adapters
From Brisbane
Is it possible or is there stud pattern adapters from 4 stud x 110mm to 4 x 114.3mm?
I want this rims with 4x110mm pattern and just wondering if I can get adapters so i can fit it to my datto
Please advise
thanks
Posted on: 2004/3/28 23:54
Re: Stud Pattern Adapters
From Sydney, Australia
No..not easy.
Why would you want Mazda wheels anyway ( )
Because they are very similar to the 4x114.3, you'd need custom hubs which are expensive.
Put simply, forget it.
Best bet would be look to convert to 5x114.3, so you can fit many wheels from bigger cars, like 200SX, skyline, late model 180sx, Commodore, Falcon etc.
That also involves a lot of thought, and replacement hubs. The rear is easy to convert, but the front is quite a bit harder.
Chris
Posted on: 2004/3/29 1:58
From Brisbane
the wheels are not the stock ones, they are very very nice ones for me.... deep dish chromes
just thought theres adapters available for this sort of application
Posted on: 2004/3/29 2:19
From Brisbane
is it illegal to have adapters in australia?
Posted on: 2004/3/29 4:07
It's so hard, that I've never seen it done. It might work for mazdas, because their hubs use bolts not nuts. But the offsets will change some 10 mm at least. This is 20mm to the track, this changes the forces put on the hub and bearings, which can only adversely affect their load capacity.
Spacers are not specifically illegal, but if a cop doesn't like the look of them then he'll defect you for them.
Unless you can get the hubs drilled out, "Let it go", I know these wheels are probably nice, but they are no good to you.
Posted on: 2004/3/29 5:44
From Brisbane
I saw some sites/company that makes these adapters mostly US based sites and some of the cars are used for racing and street use
I sent them an email anyway will see how much they cost...
Posted on: 2004/3/29 5:52
From Brisbane, Australia
maybe you're better off trying to find out if the wheels are made as "blanks". Performance for example make most of their classic wheels as blanks and only drill them to order.
Posted on: 2004/3/29 7:08
From Brisbane
L18_B110 you're right they're made to order adapters, any pattern you want
Posted on: 2004/3/29 11:48
From Brisbane
I was quoted US$388.50 for four 1" adapter/spacer inc shipping to australia
thats AU$490.22
While you can get chrome 15"x 8 lightweight steel rims for US$492 inc shipping cost
thats AU$620.82
Posted on: 2004/4/1 2:31
From Brisbane
is this worth it?
Rims from Ebay
I just love the deep dish look
or
Basset Wheels
Posted on: 2004/4/1 22:56
