« 1 (2)
Re: Twin webers and manifold for sale/ swap!!!
From Sydney
jmac wrote:
Maybe he meant THIRTY eight mm 'chokes'? not 48mm (to be honest even 38mm chokes are on the large side of things, unless it's a fairly hairy cam/head combo??......
Thats more of a plausible sizing for the choke. Even a full tilt A-series at 1608cc would probably perform better across its workable rev range with 36mm chokes. I used to run 36mm choke tubes and went back to 34mm. The end result was better punch out of low speed corners on the track
At the end of the day if the choke tubes are what have been modified, its not such a big deal to replace with an appropriate size of choice.
Posted on: 2012/5/24 0:23
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
From Sydney , NSW
I'm with Benny on this one. Not dissing you there orange1200, but I have both my cars tuned by Joe and the 1200 coupe (on the wall near the door) with an L20 had the chokes machIned out (all but removed) to 45mm. This made the carby throat (45mm) match the valve size and allowed the use of 45 webers rather than 48's. There is no way a street driven A series could have 45 ( or larger) chokes - the science just isn't there. The yellow coupe is still the highest HP n/a 8 valve carby motor he has had on the dyno
Cheers.
Posted on: 2012/5/24 10:56
All torque, no traction
A division of "My mate's ....." engineering
for the record, I wasn't having a go at anyone with my comments. I'm just as keen to get to the bottom of what specific webers they are because I would be keen to make an offer if they happen to be a pair of dcoe 9s and that they haven't been modded in some way that would preclude me fitting 36 (or possibly 34mm chokes in them.
would it be possible to get more details from the bloke who set them up please?
Posted on: 2012/5/24 11:51
John McKenzie
From Sydney
R-fast motorsports I still haven't taken my new motor to him yet every time I arrange it with him I blow something and have to cancel.. Joe remembers it cause he spent the whole day trying to get it going..
Posted on: 2012/5/24 13:40
From mandurah
Well why are you removingthem if they run fine ? Seems suss to go backwards to what youv already got
45mm carbs on most a series motors are to big and need choking heaps
I tryed helping a mate out with his fairly worked a15 that had 45s with 43mm chokes ,it wouldnt idle ,popped consistantly and ran like #OOPS# no matter what we did
Good luck with the sale
Posted on: 2012/5/25 4:58
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
From Sydney
I'm selling because my car is a daily driver and I'm spending 1/2 a weeks wages on fuel just to and from work..
Posted on: 2012/5/25 17:33
so any updates as to whether they are dcoe 9 or 13 or 152?? As I said, if they are dcoe 9s and haven't been machined out for larger chokes than would normally physically fit in there, I'll be keen to make an offer..
Posted on: 2012/5/28 7:25
John McKenzie
From Sydney
Yea just checked they're dcoe 13's
Posted on: 2012/5/28 9:15
« 1 (2)
