Browsing this Thread:
1 Anonymous Users
Re: 60-series 4-speed into 1200, how? |
From Near Bundaberg QLD
Posted on: 2012/5/24 9:17
Thanks, Sam-U-El/Racer135 --------------------------------------------- 4 utes, 1.5 sedans, 2 120Y sedans, 1 C120, 1 1600 sedan, all look like or are wrecks
Registered Users Contentmaster Usermaster
Interesting Here's Tommo's photo  Here's my photo of H150 vs H145:
Posted on: 2012/5/24 18:56
I think the only difference between the H165 and H145 flanged ends are the protruding boss bit, if the h145 one in the top pic is rotated 90deg the bolt positions look to be the same lengths. I'll have to look at the tailshaft I've got which fits the BW again, it looks like the H150 one in the pics.
Posted on: 2012/5/25 15:15
Measure the bolt-pattern dimensions, it is more accurate than a look comparison.
Posted on: 2012/5/25 18:42
I'll measure my dimensions if you measure yours...
Posted on: 2012/5/28 13:54
H145: 36 x 50 mm bolt holes. 38mm inner circle
H150: 45 x 54 mm. Inner circle 57 mm
H165: 45 x 54 mm. Inner circle 57 mm
H165 from A10: rectangular flange H150 from B310: larger round flange
H150 from Datsun B310 vs H165 from 1978 Datsun A10
Posted on: 2012/5/28 18:14
I'll go measure all my diffs and tailshafts in an hour or so.
Posted on: 2012/5/29 9:24
H145 + H165 53 x 45 x 57 centre
BW 120Y Late Model Sedan 60 x 48 x 46 centre
I'll measure the tailshafts next week, forgot to take a tape measure with me
Posted on: 2012/5/29 10:44
Edited by racer135 on 2012/5/29 12:20:50
Re: 60-series 4-speed plus other 120Y bits into 1200, how? |
Here's something else to add to the tech wiki, the early model BW sedan diffs use the same yoke pattern as the H145 and H165 diffs, and also the same brakes as the H145. The late model diff yoke mounting face also sits around 20mm further forward from the center of the axles than the H145.
Posted on: 2012/5/29 13:46
From Quairading, Western Australia
should have been clearer, I used an automatic (3N71B) Gearbox mount.... dad altered the rearmost (exhaust hanger) mount to get the gearbox to bolt up as we did NOT have a manual mount at the time... and have since had to replace the mount with another one, as I broke the left front and gearbox mounts while gearbox was in the original "Defect" and damaged the mounting pad (had to use exctra large washers to hold the gearbox still when I put it in The Defect III howevwr will be regoing over how I did it when I resurrect TD3 again soon...
I had planned to use TD3's original H145 (it's a July '74) with a H150 centre but the axles would not come out, so I pulled the complete BW68 out of the original Defect, wheels and all out and bunged that in...
Posted on: 2015/6/2 10:14
Atheism is a non prophet orginization
