« 1 2 (3) 4 5 6 ... 29 »
Re: 3J Improved Production coupe build
Looks nice wanna do mine! Lol good work I'll be doing this soon too
Posted on: 2012/1/9 8:07
Car free
From gold coast aus
looks great bryan through job as always will look great when finished
great effort to get it this far
Posted on: 2012/1/25 5:37
From Canberra
Well there has been some slow progress.
Doors, boot, bonnet and guards are finally painted.
Need to colour sand the gaurds.
Doors are rebuilt and semi attached, need door seal and some other rubber parts, drivers top hinge has too much free play so will replace.
Bonnet now has pins, front guards have been cutout and lipped (these got a little pumped when rolling the lip but it actually helps so am happy).
Pedal box is finsihed and ready for install (wilwood pedal assembly)
I haven't mounted the front velance yet, still waiting to figure out how im going to mount the intercooler/radiator. Might need to put the engine back to fit it all behind the Rad support panel.
Posted on: 2012/5/4 22:43
From MOOROODUC. Victoria
I like your side mirrors .... Can you open fully the front 1/4 window (vent) ?
Posted on: 2012/5/5 0:01
From Canberra
yes but only just.
You can move the back for more clearance.
They are ford XY GTHO mirrors available from Rare spares.
Posted on: 2012/5/5 1:22
From North Coast NSW
mcgee wrote:
yes but only just.
and also on ebay 98 for a pair! i have them on my coupe as well!
Posted on: 2012/5/10 8:36
in need of 1200 coupe parts!
From Canberra
slow but steady progress over the weekend.
Managed to finish mounting the flares, still need to be painted.
Had to modify the wiper motor to clear the controversial front roll cage mounts, it wasn't too hard, I had three to work with.
It now points down a little further to go under the roll bar.
Below are a couple of photos of the progress, finish and mounted the driver fender today as well (Not picture).
Posted on: 2012/5/20 9:02
Edited by mcgee on 2012/12/24 2:14:37
From Canberra
quick update,
Last weekend i re-mounted the engine and gearbox, had to modify the water pipe that feeds the turbo and heater box, as im not running a heater box inside the cabin, i wanted to re-route these lines.
without having the radiator support panel cut, it was harder to put the engine/gearbox back in but I think I have a method that should work (although I didn't have the flywheel on this time which made life a little easier).
With that in, i was hoping that I could move the engine back towards the firewall and have enough clearnace for both radiator and intercooler but after much angst ive decieded to go with the intercooler mounted under the bumper bar.
I think I might have made the clearance but the work required was more then I really wanted to do, a lot of rework, move engine mounts, re-cut shifter hole, shorten tailshaft and possible move seat back too.
Anyway todays effort was to get the intercooler fitted and mount the front spoiler. Happy to report that this is finished, still haven't cut the holes (70mm required) in the inner wheel arches or front valance but really this is the easy part.
tomorrow will be mounting the radiator and oil cooler.
Not everyones taste and too be honest I would have like to avoided it but the alternative was a lot more hassle.
it meets the rule requirements and the car can still be lowered another 30mm before the spoiler is at 100mm limit.
Posted on: 2012/6/2 9:12
From Sydney,NSW
Nice work McGee!
Good to see some progress.
You heading to the creek this weekend to watch?
Posted on: 2012/6/6 12:44
From Canberra
unfortunatly no I won't be able to make it this weekend.
I hope the weather gets better for the race.
On the up side more home time = more work on the car.
Posted on: 2012/6/6 13:28
