external wastegate.. is there any reall benifits?
From Sydney
hey gents ive looked all over the net but carnt/wont get the answers i need, are the turbosmart wastegates really worth the hassel? i know it holds down boost better n may gain a few HP, also dose it have to be plumbed back into the exhaust/dump pipe?
cheers guys
Posted on: 2012/6/9 12:47
Re: external wastegate.. is there any reall benifits?
From south australia
External is much better for holding higher boost pressures. But I was under the impression they are eligal for road use
Posted on: 2012/6/9 13:05
everything is illegal nowadays
external waste gates do hold boost better, you wont get more power just because you've got an external gate. turbosmart is a good quality brand so you can count on it lasting
have you been in a car with a screamer pipe when it comes on boost? its not real discreet especially for street use
Posted on: 2012/6/9 13:14
www.datsun1000.com
Current Dato -
68 B20 ute
Previous Datos -
ca18det 1200 ute 180rwkw
Stocko 1200 wagon
From Sydney
yeah they do sound kinda crapy on boost like an exhust leak haha, its only because ive picked up a manifold with a wastegate pipe for it sticking out.. i might just cut n shut it and not run one, i just thought it would help on a T28BB turbo on 10psi
Posted on: 2012/6/9 13:33
From Sydney
but if you plumb it back into the dump pipe/before the cat will that keep it sounding like a normal car instead of a exhuast leak?
Posted on: 2012/6/9 13:39
i reckon they sound sweet haha cops dont like much tho
plumbing it back tames the noise a fair bit. if your manifolds got the plumbing for it i'd use one it will save you doing it later when you want more power
Posted on: 2012/6/9 13:52
www.datsun1000.com
Current Dato -
68 B20 ute
Previous Datos -
Stocko 1200 wagon
External is better tune able and is better plumback
Posted on: 2012/6/9 14:13
Car free
From Sydney
Would I have to weld shut the wastegate inside the turbo though,( actuator rod thing ) to have the external wastegate run better/accurate boost readings? Or can I leave my turbo the way it is?
Posted on: 2012/6/9 22:08
From Brisbane
yes you will have to weld the internal gate shut, i reckon its a waste of time fitting the external wastegate to a small turbo with low boost/low power level. But you wont lose power if you do. Here is a link for external turbo housings if you want to go that route
http://www.atpturbo.com/mm5/merchant. ... Code=tp&Category_Code=GTH
Posted on: 2012/6/10 5:02
