Browsing this Thread:
1 Anonymous Users
Forester new clutch, problem? |
From Perth WA AUS
Just had the slipping clutch in my Subi 01 Forester replaced and noticed that the clutch pedal is very light, its almost like there is no clutch pressure at all but it works fine!?!? The old clutch had some feel to it and more pressure under foot. Anyone have ideas as to the cause? Pumping the pedal does not change anything, so thinking that its not air in the system. Maybe he fitted a cheap inferior clutch? Any help would be welcome, Cheers.
Posted on: 2012/6/11 14:34
Datsun 1200 2Dr sedan.
Re: Forester new clutch, problem? |
Registered Users Contentmaster Usermaster
Well if it works fine...
Test it going up a hill in top gear at lower speeds, make sure it does not slip under full power.
Maybe the old one was non-stock and therefore heavier than stock.
Posted on: 2012/6/11 17:39
stock clutch in non turbo ones is very light nige. so chances are its the pressure plate not the clutch thats making it like a girls car (which they are)
Posted on: 2012/6/12 1:39
Maybe re-used old pressure plate which is now softer than the peeps that buy them :) nah really these cars are hard to work in, CV joints often suffer, fave choice for Jewish drivers that only drove Volvos which annoyed everyone on the road & off it. Old pressure plate for sure or your Leg is used to HD pressure plate in datto.
Posted on: 2012/6/12 5:58
Re-using a clutch cover (pressure plate) is fine unless it is damaged. They don't often go soft. They often get chattered though.
Is there anything wrong with your new clutch?
Posted on: 2012/6/12 7:23
From Perth WA AUS
Thanks guys (even Mik!), I'll do the uphill test DD and see how it goes but otherwise it works perfectly, It just feels like there is no clutch there anymore. Maybe the previous owner fitted a heavyer duty clutch?
The repairer said that clutches become heavyer over the space of a couple of years and that all is well.
Posted on: 2012/6/12 8:21
I had a Mazda 323 daily that went really soft then disintegrated over a railway pass not good.
Posted on: 2012/6/12 8:29
From mandurah
so i can use a new clutch disc on my extreme clutch in my ute? its just started the slip .i adjusted the cable off abit and it has helped alot ,doesnt slip as much ,but it still slips into third if i do a stand still
when i put the locker in it would bite up hard and bog down then slowly pick up ,but now it just slips D:
hope you get it fixed nige ,might not have had any grease on the fork before the clutch was done ? or maybe there was a spring in the bellhousing that pulls back on the fork ,maybe it wasnt hooked back up
good luck buddy!
Posted on: 2012/6/12 8:52
77 1200 ute 77mm bore a15 ,12:1 comp ported and reconed h89 head fairly aggro cam ,billet rocker spacers twin 40mm solex carbs on bpro manifold MSD 6al2 with 2 step limiter 4speed 60a box hd clutch 2 inch exhaust locked 4:11 ute diff ...
Do it right away. Because a slipping clutch will quickly burn the metal surfaces of the flywheel and clutch cover.
As the clutch disc wears, it becomes thinner, and the clutch cover will not clamp it as tight. At the limit it will slip.
If the metal surfaces are not burnt, a new disc will make it like new.
Burnt surfaces will usually chatter/grab.
Posted on: 2012/6/12 8:56
From mandurah
ok well it only slips in third on the spot so it might not nbe stuffed yet ,its only done it 2 or 3 times and i then realized it was forked so i stopped doing it haha
well ive got a near new clutch kit at home with a disc thats immaculate and has only done about a weeks work so i might rob the disc from it
Cheers DD!
Posted on: 2012/6/12 9:02
