« 1 (2) 3 »
Re: WTB FR17 Simmons
they do 22's lol they never used to go that big did they?
Posted on: 2012/6/12 13:00
www.datsun1000.com
Current Dato -
68 B20 ute
Previous Datos -
ca18det 1200 ute 180rwkw
Stocko 1200 wagon
From Narellan,Sydney
Thnk they could always do them but back in the day 22" weren't Evan heard off until the last couple years
Posted on: 2012/6/12 13:10
All stainless steel-mild steel Sheetmetal and tube work
All types of welding
Custom metal polishing
BSA custom fabrication 0415 904 474
From Canberra
Nah only went to 19's. The rx3 UNTAMD had FR19's on the back with a custom stepped lip which made them 20's (like they used to do to make FR18's) but there were never factory FR20's before they started re-making them.
Posted on: 2012/6/12 13:54
YLD.18L
From Canberra
What is the offset on a set of FR17's????
Would a set of FR17's by 6" fit clean on the front with out rolled guards or hitting the strut?
Posted on: 2012/6/12 23:44
From Canberra
They make them to whatever you want
Posted on: 2012/6/13 0:05
YLD.18L
From Canberra
Cool so technically a set of fr17 with +30 offset would fit clean under the front with out hitting the strut (ie. stanza strut) and fit inside the guard without them rolled.
Wonder if it would scrub the guards tho on full lock with say 175 or 195 tires??
I have not seen anyone on here running some fr17's on a 1200 ute.
I wouldn't mind having a set of FR17's along with my weld dragway's just cause always liked the fr's
Posted on: 2012/6/13 3:11
They may be pushing it I had 195 on my old setup and it rubbed the struts I now have stanza struts with coil overs and picked up 2x 165/35/17 Tyres yesterday which should give me heaps of Clarence :)
Posted on: 2012/6/13 3:46
From Canberra
What offset and width do you have running on the front datrotor?
Posted on: 2012/6/13 4:16
I am still in the middle of working the exact offset out with my wheel people but im getting a 5.5" rim whmade which really makes it a 6.5" rim overall cause it's always 1 size bigger then the rim widtg
Posted on: 2012/6/13 4:28
From sydney
hi loosekid,I have fr17s on my dato ute,size of tyre on the fronts are 205/40/17.
my front guard lips have been slighty flared,and the inner guards(the footwell area) have been modified to suit.
running no spaces on them,using stanza struts.
hope this gives you a idea.
thanks
Posted on: 2012/6/13 5:35
« 1 (2) 3 »
