« 1 2 (3) 4 5 6 »
Re: Which would be easier to install rotary or CA18DET
From Wanneroo, Western Australia
Andy, the A series they're referring to is what originally came in your ute (A12 L4) and I agree; a hot A series is the best way to go, especially with your limited knowledge. Get your A12 bored/stroked using other A series pistons/conrods/cranks and make it BREATHE with a set of sidedraught Webers and extractors. No engineering needed (the engine stamp is still A12!), reliable as #OOPS# and easy to work on. You have to learn to crawl before you walk.
Posted on: 2012/6/13 4:55
From Goldcoast
Oh ok, Well this is what I know about my engine, maybe you guys might be able to give me some pointers of what I should look at doing to it next.
It has a recent topend rebuild,
new head not sure if its just a standard one
new pistons & bearings
mild sports cam
sports exhaust
extractors
A webber carby.
I will be pulling the engine out for a complete respray.
jpg  sss.jpg (131.41 KB)
16498_4fd8184c66ad3.jpg 640X480 px
Posted on: 2012/6/13 5:34
That's a pretty typical rebuild/mod, maybe now it has 75hp instead of 69hp.
For $5000 you can build an A12 to 120 HP, or buy the previously mentioned 170kw A12 for $1800.
Posted on: 2012/6/13 5:58
From Goldcoast
Ok are these A12 engines fairly easy to find, or are they as rare as rocking horse #OOPS#?
And where would the best place to start looking be?
Thanks heaps for all your help :)
Posted on: 2012/6/13 6:48
Not rare -- they came in every 1200 and 120Y ever made.
Posted on: 2012/6/13 6:53
From sydney
Just keep an eye out on the forums for a worked A14 or A15, ones bored out to 1600cc with twin Webers all the good bits professionally built generally sell for $3k to 3.5K second hand.
Posted on: 2012/6/13 7:02
From Goldcoast
Just wondering I take it that their is alot of difference between the A12 that come out in my ute and the A12 that came out in the 120Y?
Posted on: 2012/6/13 7:42
1974-up A12 120Y or 1200 ute is the same
1971-1973 A12 is different
Posted on: 2012/6/13 8:01
From Goldcoast
Ok so im just trying to get my head around these engines so in one of your previous posts you wrote you can build an A12 to 120 HP, or buy the previously mentioned 170kw A12 for $1800.
Being as my ute is later than 1974 this means that means it has the same engine in it as the 120Y and that is the engine that you mentioned could buy for $1800 at 170kw.
So basically I have the good A12 in my ute already.
If that all makes sense.
Thanks
Posted on: 2012/6/13 8:15
From A.C.T
I rekon get a ca18 turbo you wont be dissapointed! plus everyman and his dogs done it so theres tones and tones of info on it and theres plenty of places to get mod'ed parts. but in all honestey it will be much cheaper and less effort to jst buy one someone else has poured 40 grand into and are jst keen to piss off for under $20,000
Posted on: 2012/6/13 9:08
« 1 2 (3) 4 5 6 »
