« 1 ... 1751 1752 1753 (1754) 1755 1756 1757 ... 1777 »
Re: PERTH BOYS.. GO THE DATTO
From mandurah
nige ,i have the rigth tie rod end and tie rods to make the s13 knuckles work with the 1200 front end ,
you can have them ,there in the coupe ,new tie rod ends and sunny tie rods
Posted on: 2012/6/14 17:54
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
From Perth WA AUS
Thanks Jess but the overall weight of the set up is the reason I'm offloading them.
Posted on: 2012/6/15 10:17
Datsun 1200 2Dr sedan.
From Perth WA AUS
Here we go 120013b, for some reason I had trouble uploading this pic.
jpg  image.JPG (36.69 KB)
9665_4fdb06bd40264.jpg 578X433 px
Posted on: 2012/6/15 10:56
From Perth, West Aussie
Hey can anyone here get good prices on suspension? I've got my eyes on a nice set of bilstein shocks, but the retails a bit of a killer!
Posted on: 2012/6/16 12:36
From mandurah
i can mate ,i got accounts with covs repco veales and pedders
what to suit?
nige stop being a wieght weeny! just run what works ,use the setup i gave you ,if you want light weight get 200b then go coilys and 200b brakes ,mines mint and it handles awesome ,and i just finished shortening the struts so it sits realy low now haha illo have to put a pic up soon
Posted on: 2012/6/16 16:19
77 1200 ute
4speed 60a box
hd clutch
2 inch exhaust
From mandurah
oh and shoom can have the tie rod ends if he is taking the brakes ,i got no need for them haha
Posted on: 2012/6/16 16:21
77 1200 ute
4speed 60a box
hd clutch
2 inch exhaust
I really only need the hubs, spindles, discs , uprights, calipers and caliper mounts. It's to do an (eventual) brake / stud pattern conversion on a 520 wagon. so I really don't have to get everything else.. if anyone has any contacts to get the rear gear I would be happy to hear from you! .. yea so that's what it's for (the suspension) I only really need the rear shocks - which is Bilstein part No: 606493 . gonna put some cheaper shocks on the front for rego as I'm going to do a 720/D21 coilover conversion.
Posted on: 2012/6/16 16:44
and Do you know anyone in town that knows their way around a KA24DE ? I basically am going to get all the machining / balancing farmed out and done myself as much as possible. Just need someone that's got all the machinery to do the final assembly and all the measuring equipment to make sure everything is in spec etc. don't wanna spend 4 grand on an engine and have it pop before 100 thousand ks, when I could have spent an extra $500 on something and had the piece of mind. basically I want to do as much as i can and someone that will be able to check my work and be able to do all the specialist stuff that I don't have the gear / not feasible to buy for home use. And please don't say the ping is power guy ;)
Posted on: 2012/6/18 19:50
did you get some yet nige?
i bet you put em in your mouth
Posted on: 2012/6/19 11:43
From Perth WA AUS
Yeah Snickers are nice, where do you put them Mik????
Posted on: 2012/6/19 12:08
