120y manual pedal?
From vic
hi i was wandering if you convert an auto to manual what do you do to put in a clutch pedal do you change the whole thing with accelerator and brake from a manual car or are they same as auto and you just get a clutch pedal?
how does it get installed? does the brake pedal size change from auto to manual in a 120y?
Posted on: 2012/6/26 13:05
Re: 120y manual pedal?
From Melbourne, Australia
brake pedal changes just cause the manual one is smaller pad
clutch just gets added also, cant remember if the pivot bar is interchangeable, i think so though, the auto one just has a spacer where the clutch should go
Posted on: 2012/6/26 13:07
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From Sydney
auto and manual pedal boxes are different in 120y's and there are 2 types of manual pedal boxes, with or without a booster .
Posted on: 2012/6/26 13:52
From vic
so do i have to change the whole thing? from the wrkers do i remove every thing accelerator brake and clutch pedal
mine has a booster on it i think (black drum kind of thing near brake resivour)
are all these 3 pedals on one bracket plate that come out all together?
Thanks!
Posted on: 2012/6/26 14:04
From Sydney
remove the whole thing
here's a pic of 120y pedal boxes the one on the left is no brake booster type
Posted on: 2012/6/26 23:35
Yes, there were four different ones: Auto vs Manual X Boosted vs non-boosted
Manual pedal boxes have an extension welded on the left side. So they are not interchangable with Auto.
For B110, the pedal boxes are the same manual & auto.
Posted on: 2012/6/27 0:11
