tokico front shocks for a sedan??
From Midway City, California
does anyone know what tokico shocks i could use with a set of ground control coilovers for the front of a sedan?
thanks in advance
Posted on: 2012/6/24 5:19
if it was easy to restore, they would call it chevrolet
don't piss off America, or we will bring democracy to your country
Re: tokico front shocks for a sedan??
hey moises
you can use any strut insert cartridge shocks you want with the Ground Control coilover kit
See Strut Insert Part Numbers
Are you using the stock 1200 struts, or have they been replaced with something else like 280ZX struts?
Posted on: 2012/6/24 5:29
no, im going to be using the stock 1200 struts, with 210 brakes.
Posted on: 2012/6/27 6:27
Excellent -- keep it light weight, but use the larger 210 brakes.
You can get Konis or Tokicos (new old stock) for the 1200 struts, or buy the genuine items from Nissan.
Some guys cut their struts down shorter when lowering more than 2", then they use VW Golf inserts.
Posted on: 2012/6/27 7:25
what tokico shocks i could use ... for the front of a sedan?
TOKICO S1041 (oil), Z1041 (gas)
These are inserts for the stock 1200 struts.
Posted on: 2012/6/27 7:56
From Sydney, NSW
id say go the vw golf inserts my mate just used them on his 1200 sedan and got a low ride height and very stiff with plenty of travel on the shock. just have to cut the strut down and reweld the sleeve
Posted on: 2012/6/27 9:39
Snapped crank and still smiling, How do I do it? LOL
You can use the Golf cartridges in a stock 1200 strut also, with a simple spacer.
But Tokicos for Golf won't fit, they are too big around. KYB for Golf will fit.
Tokico seems to be the hot name in suspension now in USA. Which is humorous because Tokico and KYB were original equipment for the Datsun 1200 back in in 1971.
Posted on: 2012/6/27 9:56
From Sydney, NSW
yeah he used the kyb golf ones, in a 120y strut with s13 cambertops and 6 kg springs, a very good suspension set-up and so worth the 400 for all of it
Posted on: 2012/6/27 13:20
ddgonzal, im having trouble finding the golf inserts. do you know where i can get them?
Posted on: 2012/7/1 5:07
From your local VW dealer. Or from Amazon.com or from eBay.
For example,
http://www.autopartswarehouse.com/sho ... rt/volkswagen/rabbit.html
Posted on: 2012/7/1 5:26
