« 1 2 3 (4) 5 6 7 ... 29 »
Re: 3J Improved Production coupe build
From Brisbane, Australia
Posted on: 2012/6/14 8:57
Edited by L18_B110 on 2012/12/24 3:42:03
From Canberra
L18-B110,
Of course not! That would be against the rules.
It is however a replacement panel, not sure where I got it from though??
Posted on: 2012/6/28 4:57
interesting, i keep thinking there are two differnt ones
Posted on: 2012/6/28 5:15
From Trinidad and tobago
nice 12.Great two tone.! Thumps up mate.
Posted on: 2012/6/28 5:16
'71 Four Door Sedan.
Street Sleeper!
STILL LIVIN' THE 70'S LIFE !!
From Canberra
must be two different designs then???
Maybe mine is a czechoslovakian one, not sure.
It does fit the radiator width/hight and oil cooler well though, almost as if it was made for that combo, I guess it was one of these really lucky finds.
Posted on: 2012/6/28 5:26
Posted on: 2012/6/28 6:28
Edited by L18_B110 on 2012/12/24 3:42:27
From Canberra
I can't believe how long it has been since last update.
I need to take some photos and update the thread.
After discussions with the eligibility officer I've had to do some rework on the seat mounts. I cut into the trans tunnel, which apparently isn't allowed. So I've taken to opportunity to fix the seating position little, moved it a little higher and back.
Bought most of the lines for brakes, oil cooler etc and re routed the fuel lines.
Have retrimmed the dash and door panels.
The motec gear is on order. M84 and CDL3 combo. Looking forward to installing these after christmas.
Heading up to Brisbane soon and will take my front brakes up to have a machinist friend help with making it all fit together.
Hopefully by the end of today i will have the seat mounts finished and most of the holes drilled for the intercooler plumbing.
Posted on: 2012/12/8 21:09
From Canberra
I finished the seat mounts and redid the trans tunnel, a couple of photos are attached.
Posted on: 2012/12/10 6:40
Edited by mcgee on 2012/12/24 2:10:37
Edited by mcgee on 2012/12/24 2:11:57
From Canberra
Christmas came a day early today :)
New motec M84, CDL3 track logger kit, upgraded Shift light module (Full version not clubsport) and of course UTC to talk to ECU.
Looking forward to getting into the wire loom soon.
Still got a heap of work to do.
Posted on: 2012/12/24 0:08
Posted on: 2012/12/24 0:48
Edited by L18_B110 on 2012/12/24 1:15:36
Edited by L18_B110 on 2012/12/24 1:16:29
Edited by L18_B110 on 2012/12/24 1:16:58
Edited by L18_B110 on 2012/12/24 3:36:24
