« 1 ... 3 4 5 (6) 7 »
Re: My Little Project on Datto
From Perth WA AUS
Wow! nice job your doing there Sumith, lots of work.
Keep it up mate you will love the car when its finished and be proud that you rebuilt it. :)
Posted on: 2012/6/8 10:26
Datsun 1200 2Dr sedan.
From Sri Lanka
Hi Guys
Hi Guys
Prepared the differential with new Oil and Started rear suspension work with leaf spring bushing etc,Had issue of inserting upper Bush on leaf spring,Was struggling with hell of work whole day work got stuck in middle finally went through the Repair manual ,damn 8 bushes were differ from original specs,
i have bought OEM 55046-H5001 Bushes instead of OEM 55044-H5001 Useless day of Sunday went all over the places couldn't find them,finally decided to go for 55046-H5001 and cut extra rubber from inside to make it little bigger inner diameter.
thanks
regards
sumith
jpg  1.jpg (70.72 KB)
10994_4fe9803124d0b.jpg 640X480 px
jpg  2.jpg (80.88 KB)
10994_4fe9803d85eee.jpg 640X480 px
jpg  3.jpg (74.33 KB)
10994_4fe9804a28335.jpg 640X480 px
jpg  4.jpg (58.97 KB)
10994_4fe980561aa31.jpg 640X480 px
Posted on: 2012/6/26 10:27
Not too shy to talk
good work this is were i am at with my wifes datto keep going you will love it
Posted on: 2012/7/1 14:29
From Sri Lanka
Hi Guys
Time has gone far a lot ,but i am behind the time as of restless life, meanwhile my projects is also going slowly,don't blame me taking so long time,all these suspension parts and leaf springs differential have been fitted to the car .
and also new Brake master Pump.brake pads brake washers brake pistons caliper etc in.
and painted radiator front grill fuel tank and also managed to oil primer coat and half of surface filler to the car ,
Next finishing target has been set to April, will try to strict to the schedule
Rebuilt the engine with new set of bearing and ring set with Standard size pistons and new set of valves and guides along with a head refacing ,
Don't mock me if the things are not good , this is ever my 1st Spray Paint Experience.
thanks
regards
sumith
jpg  1.JPG (67.21 KB)
10994_512d8f8b9cac7.jpg 640X480 px
jpg  2.jpg (73.19 KB)
10994_512d8fbfafef7.jpg 640X480 px
jpg  3.jpg (73.86 KB)
10994_512d8fcbaa38e.jpg 640X480 px
jpg  4.jpg (68.92 KB)
10994_512d8fd5326b0.jpg 480X640 px
jpg  5.jpg (103.90 KB)
10994_512d8ff034c55.jpg 640X480 px
jpg  6.jpg (100.02 KB)
10994_512d9002dbe4a.jpg 640X480 px
jpg  7.jpg (100.74 KB)
10994_512d9012db0f1.jpg 640X480 px
jpg  8.jpg (97.45 KB)
10994_512d901e34af8.jpg 640X480 px
jpg  9.jpg (89.76 KB)
10994_512d903b33c8c.jpg 640X480 px
jpg  10.jpg (52.58 KB)
10994_512d90477d740.jpg 640X480 px
jpg  11.JPG (58.85 KB)
10994_512d9053195ab.jpg 640X480 px
jpg  12.JPG (95.88 KB)
10994_512d905d00b75.jpg 640X480 px
jpg  13.JPG (47.95 KB)
10994_512d9068e12ea.jpg 480X640 px
jpg  14.JPG (70.55 KB)
10994_512d907492f5b.jpg 640X480 px
jpg  15.JPG (72.23 KB)
10994_512d9086c8167.jpg 640X480 px
jpg  16.JPG (63.90 KB)
10994_512d90917a207.jpg 640X480 px
jpg  17.JPG (62.68 KB)
10994_512d909cc8000.jpg 640X480 px
Posted on: 2013/2/27 4:50
From vic
hey may i know what this oil primer stuff is? does it stop rust? why not use something like epoxy primer on bare metal"?
Thanks!
Posted on: 2013/2/27 5:14
From Sri Lanka
Hi a12datto120y
the whole car was not the bare metal , but some areas that body work was done ,
First i out a oil primer coat for the whole car and then sanded it with fine grit 400 ,and then put a filler on it
thanks
regards
sumith
Posted on: 2013/2/27 5:46
Edited by Sumith on 2013/2/27 6:27:26
Edited by Sumith on 2013/2/27 6:28:23
Looks good Sumith.
In our countries the term "oil primer coat" is called solvent-based paint also known as oil-based but more commonly called alkid-base. As opposed to water-based paints.
Posted on: 2013/2/27 6:21
From Sri Lanka
Hi Guys
Just Bought Brand New Ignition Coil,Plug wire Set ,Ignition Condenser,Spark Plugs ,Carburetor Repair Kit,rotor etc needed for the engine.
thanks
regards
sumith
jpg  4.jpg (67.33 KB)
10994_51344e490d2b9.jpg 640X480 px
Posted on: 2013/3/4 7:33
From Sri Lanka
Hi Guys
In which stage should i start to assemble my car parts like
Windscreens
Door Glasses
rubber beedings
door locks
winders
door handles
engine gearbox etc
1. after the primer coat
2.After the base coat
3.after the top coat
4.after the clear coat
right at the moment mine is on the completion of first epoxy primer coat
thanks
regards
sumith
Posted on: 2013/3/8 4:43
From Sri Lanka
Hi Guys
Reassembled the Starter Motor Cleaned the stator and armature and will be installing a new set of brush set soon,and found viper motor was in good condition i used it sparingly it used to stuck the moving arms always
and reassembled the carburetor with rebuild kit with factory specs jets.
Had to put little putty on minor scratches found on the behind and behind doors together and wet sanded them to the smoothest possible,found that the filler primer was not enough thick to keep it strong enough when sanding and found my gun tip was smaller than paint manufactures specs ,no problem there will be another complete filler coat later on,so had to put a little oil primer on those areas to avoid them get rust by next week end
thanks
regards
sumith
jpg  1.jpg (68.59 KB)
10994_513d6ae933bba.jpg 640X480 px
jpg  2.jpg (72.47 KB)
10994_513d6af1872a3.jpg 640X480 px
jpg  3.jpg (66.14 KB)
10994_513d6aff03e5a.jpg 640X480 px
jpg  4.jpg (65.88 KB)
10994_513d6b0b40d4c.jpg 640X480 px
jpg  5.jpg (54.65 KB)
10994_513d6b1a81c30.jpg 640X480 px
jpg  6.jpg (64.63 KB)
10994_513d6b2390c9e.jpg 640X480 px
10994_513d6b2c07677.jpg 640X480 px
jpg  7.jpg (76.67 KB)
10994_513d6b3601610.jpg 640X480 px
jpg  8.jpg (76.63 KB)
10994_513d6b3da8137.jpg 640X480 px
jpg  9.jpg (64.77 KB)
10994_513d6b45dcf89.jpg 640X480 px
jpg  10.jpg (50.49 KB)
10994_513d6b4fdf1ad.jpg 640X480 px
jpg  11.jpg (64.54 KB)
10994_513d6b57ed06a.jpg 640X480 px
jpg  12.jpg (50.49 KB)
10994_513d6b60919ca.jpg 640X480 px
jpg  13.jpg (58.58 KB)
10994_513d6b6b7c590.jpg 640X480 px
jpg  14.jpg (60.02 KB)
10994_513d6b734c555.jpg 640X480 px
Posted on: 2013/3/11 5:28
