Wtb Vic 175/55/15 semi slicks
Where to buy? And what to get but needs to be semi slicks and 175/55/15
Posted on: 2012/7/6 7:18
Car free
Re: Wtb Vic 175/55/15 semi slicks
From Brisbane
good luck. i had to go 175/55r15 on the front of mine for strut clearance after changing the offset. not a very common size. i only know of 3 makers in a "normal" tyre let alone semi slick. i have khumo kh11.
pm me with what you come up with.
Posted on: 2012/7/6 8:01
From Melbourne AUS
why so skinny?
if your running 15's i'd go at least 195/50 or 205/50 if you have the room for them
Posted on: 2012/7/6 9:32
1973 B110 A12
From Sydney
+ 1 for good luck to you, not being rude, hard size to get and I'm sure the speed ratings are low, something like 140km/h. 185-55-15 should be easier to get in a slick I would say
Posted on: 2012/7/6 10:42
I will be running 15x7 p8 with 240z struts with series 1 maddat rx7 series 4 brakes fc3s and need to reduce tyre size so I don't need flares just a bit of a pump and lip and off I go! On the rear I'll be running 225's plus
Posted on: 2012/7/6 10:53
Car free
Use 185 55 15 or 50 profile. You will scrub those 175 out with no traction and all that power planned.
Posted on: 2012/7/6 11:08
Might have to look at 185/55/15 federal 595's then
Posted on: 2012/7/6 11:27
Car free
From A-TOWN
Posted on: 2012/7/6 11:28
Can anyone help me to get from os?
Posted on: 2012/7/6 11:38
Car free
datsunbloke,
the only way to import tires is by them being on rims.Can't import tires only.
suppafato,
those sizes are hard to come by esp in slicks.just keep searching or change to different size mate
cheers
Posted on: 2012/7/6 11:40
