« 1 2 (3) 4 »
Re: Camber Adjustment
From Western Australia
Cheers DD
Nice decipher.
If my LCA was knackered would that be the reason the car pulls to the right also?
Any idea where I can get right LCA now days? I'm in Perth W.A
Posted on: 2012/7/6 0:08
1974 1200 Ute - Build
yes, whatever is causing the tyre to be that far back is causing the pull to one side.
Take you tyre off and look. You can probably see what's wrong. Or take soem pics and put them here.
Posted on: 2012/7/6 0:34
Strangely I went and bought 4x new tyres and got them balanced. The car still pulls to the right but no where near as bad. It drives heaps better...
Posted on: 2012/7/7 5:44
Good on ya. My alignment shops wouldn't work on the car if the tires were in bad shape.
Posted on: 2012/7/7 5:47
any idea of an easy way to stop front tyre rubbing back of wheel arch? now the car drives ok I dont want to mess with struts etc...
thinking maybe panel beating?
Posted on: 2012/7/8 9:57
That's masking the problem. Do it right. Either get new castor bushes or then get struts.
Take to your local pedders and get that $14 suspension check. Or you local friendly mechanic
Posted on: 2012/7/8 10:09
From Melbourne, Australia
I feel like I'm belting my head against the wall.......
Posted on: 2012/7/8 10:40
Current Fleet-
1996 R33 GT-R Skyline
1996 Falcon XH XR6 Ute
1977 Datsun 1200 Ute A14 (Fergus)
2012 VW Passat TDI Wagon
Is that the only thing your beating???
Posted on: 2012/7/8 10:45
No.
There are other things......
Posted on: 2012/7/8 11:05
Current Fleet-
BeeJJ I could tell you exactly what needs to be replaced if you bring it by my house so I can look at it. Otherwise you can inspect it or have a shop inspect it. This type of symptom requires inspection.
Posted on: 2012/7/8 18:32
« 1 2 (3) 4 »
