« 1 ... 17 18 19 (20) 21 22 23 ... 97 »
Re: Super Bee Z24 Mod
Full groove that goes right around for oil I guess instead of just one bearing both bearings top and bottom have the channel. You can use a turbo L28ET oil pump I think for extra oil unless the KA24de one is the same cant remember.
Posted on: 2012/7/14 4:32
From Snohomish, WA USA
Thanks.
The oil pump on the ka is on the timing cover and works off the crank.
I should probably look into getting these bearings.
Posted on: 2012/7/14 16:28
'73 2 Door Sedan
Crower Stage 3 Cams/SS Valves
Forge CP Pistons/ Eagle Rods
Ford 8.8/Mini Spool/4.11
Ok, how about 'P' series bearings. I cant find any 'H' series on ebay but i find the 'P' series.
Posted on: 2012/7/14 21:42
'73 2 Door Sedan
I'm not sure that you'd want harder bearings. The oil film is what keeps the bearings from getting damaged, so make sure the oiling system is perfectly modified.
Have you check what they recommend on KA-T.org? The site specializes in discussing boosted KAs.
Posted on: 2012/7/15 1:02
KA, Z and L series pumps all interchange good to make sure you have the best one
Posted on: 2012/7/15 1:59
Right now I have King bearings in there. Some of the build site say they use those bearings. I'm going to talk to crower on monday. I'll research the oil pump is well.
Posted on: 2012/7/15 4:09
'73 2 Door Sedan
Finally a decent race day. Thought it would get rained out the sun is partly shining. Lets see goes it goes today on the 1/8th mile.
Posted on: 2012/7/15 20:02
'73 2 Door Sedan
Well I broke out in my bracket again. I put in my time trials in the morning And then raced in the trophy round in the afternoon. Of course it was cold this morning and hot in the afternoon. Enough to make 150 pound pressure change in my nitrous bottle. I was running a constant 8.1 sec on each pass which pretty much guarantees a trophy place. I won the first race easy so i let off the pedal before the finish line. We dont have time to get our run times unless you have someone get it for you. Well the next race was closer so i held on a bit longer but still let up at the end. I ran a 7.9. I hate it when the guy points you to the pits. Looser!!!
Drove the car right onto the trailer , grabbed my times and bolted out of there.
Car ran good but i am hearing that 3rd rod bearing getting louder.
The touring Drifters will be out at the track next week so i'll be hitting them up for questions on the KA build. :)
Posted on: 2012/7/16 1:15
'73 2 Door Sedan
Why the finger to the pits?
good times for the stump puller :)
Posted on: 2012/7/16 2:16
When you're done racing there is a guy that sits and the end of the track around the curve that either waves you through if you win or points you to the pits if you loose.
Its a crap shoot. :)
Well not really. The lighted tree tells them who wins. We just dont know until he points.
Posted on: 2012/7/16 3:38
Edited by datsa73 on 2012/7/16 4:02:24
'73 2 Door Sedan
