« 1 (2)
Re: R30 stumpy box
From Geelong, Vic
would be good to have all the gearbox ratios listed somewhere so you could see which ones have decent ratios
Posted on: 2012/7/16 1:47
Re: R30 stumpy box
Ratios for 720 / Navara are wider at 3.592, 2.057, 1.361, 1.00, .852.
link from ozdat- some one take the info and sticky in the wiki.
Posted on: 2012/7/16 14:17
Re: R30 stumpy box
180B SSS - 3.382 - 2.013 - 1.312 - 1.000 - 0.854
Stanza ss dogleg - 3.321 - 1.902 - 1.258 - 1.000 - 0.864
Posted on: 2012/7/16 14:21
Re: R30 stumpy box
thats not bad 1:1 fourth is just what it should be
but compared to the other boxes 3rd is also fine
on the navara box the problem is 1st gear is as good
as a T50 toyota box the other gears are fine or very
close to the other 71c series boxes.
Posted on: 2012/7/17 12:47
Re: R30 stumpy box
Anyone know if the 1st gear is interchangeable in a navara box with any of the other box's listed here?
Posted on: 2012/7/18 13:50
Re: R30 stumpy box
From Geelong, Vic
you should pe able to change the gearset to one from another 71c easy enough, plenty of silvia boxes and stuff around
Posted on: 2012/7/19 1:10
« 1 (2)
