« 1 2 3 4 (5) 6 »
Re: I am a VSCCS Engineer - NSW Registration of Modified/Altered Vehicles
From newcastle
thanks for the reply. well its nearly time to come and inspect before i proceed any further might blow the dust off and get you to come around for a chat and let me know what needs to happen. thanks again
Posted on: 2012/7/25 12:19
at first you dont succeed, cut a bit out and put a bigger one in!
85 1200 ute ca18det project build
if i was an engineer doing my own car i would haha
here's the chart page 11
http://www.infrastructure.gov.au/road ... A_Engine_01jan2011_v3.pdf
just read thru it and if the 1200 is classified as a commercial vehicle its says there's no actual recommendation for a limit, have i interpreted/read that right?
www.datsun1000.com
Current Dato -
68 B20 ute
Previous Datos -
ca18det 1200 ute 180rwkw
Stocko 1200 wagon
From Sydney
mattkinsela - No worries, feel free to give me a call if you want to organise something or just need a bit more info.
Lethal_john - Yes, you have read it correctly. If the vehicle is a commercial vehicle (category NA) there is no set limit, however as I said just before if it isn't safe then no engineer will put his name on it.
Regards
Matthew Rog
M.R CORP
0499234218
Posted on: 2012/7/25 13:25
From Canberra
Can someone help me and provide me with the VSCCS engineering authorised list from the RTA website.
I can not find it currently. I last looked at it about 2 months ago but can not see it currently.
I'd love to have you look at my car matt but you are just a little bit too far away from canberra to cart the car around.
Posted on: 2012/7/26 0:00
From Canberra
Ahh never mind did alot more researching and finally found it :)
They like to hide it deap down on the RTA website.
http://www.rta.nsw.gov.au/registratio ... ads/vsccs_bulletin_01.pdf
Posted on: 2012/7/26 0:13
From Sydney
Is your car registered in ACT or NSW?
Posted on: 2012/7/26 2:08
From Canberra
IT's NSW - Queanbeyan NSW just outside canberra itself.
Posted on: 2012/7/26 3:18
From Sydney
Ah ok no worries. Let me know if you decide to make the trip up to Sydney.
Posted on: 2012/7/26 7:40
From Sydney, NSW
so you can put an SR20DET into a ute with the right mods to make it safe?
Posted on: 2012/9/6 9:13
Daily: 2000 Holden VX Calais 5.7L GenIII
Datto: 1972 Datsun 1600 L20B twin 40 DCOE Webers
From Sydney
Technically yes, I would be very serious about the brakes, suspension and tyre requirements if it were to be done. The traction setup in the rear would also need to be fairly substantial. If you can't accelerate in second gear without burning rubber then it wouldn't be classed as safe...
I did some compliance for a well done ca18 coupe just last week and it was very drivable due to the use of properly reset leaf springs and semi slick tyres.
Posted on: 2012/9/7 13:21
« 1 2 3 4 (5) 6 »
