« 1 (2) 3 »
Re: Nearly there! a15 twin turbo
From Perth W.A
your a walking contradiction b120dat, not very old skool is it.
so 1200RC once this works all you have to do is get a manifold hade up and everything else and you can bolt up your TT to the injection.
you should apply to your uni for a study grant, and get them to pay for manifolds and engine management.
Posted on: 2004/4/5 14:03
120y Coupe
120Y coupe Race car (SOON)
120Y Sedan for the Lady
From Melbourne, Australia
Yeah injections on the way, i was just so sick of this thing sitting in the shed i had to put it together somehow (i pretty much had all the bits for this on the floor of my shed so why not..), if ya wanna see the injection on sooner offers of charity are more than welcome
just kidding, i just need to get a bit more money behind me and i will be replacing the carb with injec, it wont be too hard-a-swap from here to get the injection on
Posted on: 2004/4/5 14:04
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
team dat
i dont even need to make a manifold, all i need is the computer to run the injection, and then to get it all tuned up
i also what to add the low comp head when i do the injection, which is worth a couple a hundred aswell
problem is im a bum, i have no job at the moment, might have to start delivering pizza me thinks
Posted on: 2004/4/5 14:12
1200 Coupe Rallycar
From Perth W.A
Well with TT you won't be late for any deliveries!
Posted on: 2004/4/5 14:17
120y Coupe
From Brisbane
yes, well when it comes to OLDskool with turbo's, injection wins everytime but then webers can be converted to Injection too ehehehe
Posted on: 2004/4/5 14:19
OLD SkOOL POWeR!!! [color=CC0000]"with the sound & smell of twin 40s at full throttle!!!" [/
From Perth Austarlia
is that radiator hose??? being used on the turbo plumbing?? if so, has anyone else used it and how long does it last???
Posted on: 2004/4/5 14:31
yeah from the old setup it seemed to be getting a little soft but hard to tell, i used new thicker hoses this time, but i think if i was to use the proper stuff id need to make up all new piping to minimise the amount needed and so that i only needed straight pieces
if ya think about it the water gets to 100 degrees in the cooling system (i read turbos get the air to around 65degrees) and to test for leaks in cooling systems they pump 20psi pressure into the system, so it should be able to take it, i think the proper stuff is just wank really
Posted on: 2004/4/5 14:39
1200 Coupe Rallycar
65 degrees???
In one of my old cars I had probes in ht eair, and it read up to 120 degrees before the I/C
Posted on: 2004/4/5 15:26
Datsun 1000 ute - Building (slowly)
Datsun 1600 13B turbo - coming soon
yeah ok cool, still at 120degrees it would be within the design range of the radiator hose as with coolant the boiling point of water is close to that anyway
did you measure temp after the IC, just curious at how effective the IC was???
Posted on: 2004/4/5 15:30
1200 Coupe Rallycar
My I/C was too small in that particular car.....and after flogging it for a while the temp would get up to 100 degrees.....water spray would drop it back down to around 60 - 70 and make a big difference in power.
I reckon in my 13B 1600 temps after the I/C were not much higher than ambient. but I never measured
Posted on: 2004/4/5 15:41
« 1 (2) 3 »
