Pistons??
From Trinidad and tobago
Hey Boys an Girls!
I have a question.I Have a 15 Pistons,Since they are Low Compression..and I put a14 Piston Top on a15 Rods Because a14 is High compression..
What would i Gain or loss?change in compression ??
Cheers Darren.
Posted on: 2012/8/15 1:58
'71 Four Door Sedan.
Street Sleeper!
STILL LIVIN' THE 70'S LIFE !!
Re: Pistons??
From Freo
they will stick out the top of the block unless you get them machined...
Posted on: 2012/8/15 3:36
A15 PSI Project Motor
'72 CB750k,
Re: Pistons??
From Christchurch NZ
You're better off to use Mazda/ford laser E5 pistons. They will need the small end of your conrods opening up to take them, but with a small deck cut on your block you'll get a good hike in compression.
Posted on: 2012/8/17 8:23
Forced Induction!
Re: Pistons??
all of the above yes but also if you have the a14 pistons machined to clear the valves then you get high comp in the best way possible.
Or you can buy some of peters forged pistons for cheap he advertised them recently, very high comp with valves recesses already done.
Posted on: 2012/8/17 10:01
