Brakes
From Brisbane Qld
Hay guys my brakes are fading. My mechanic send the master cyclinder
is on its way out I thought Maby one day i could upgrade The hole system
What would be Easyest And cheap convertion for B310 sedan?
Posted on: 2012/9/8 23:28
Re: Brakes
From Geelong, Vic
Brake/strut upgrades
Have a look at that. Most of the larger struts will bolt staight in. If you dont want to modify anything then R31 struts probably have the best brakes. Or 180b struts with commodore calipers is pretty easy, only need to modify the disc and space that caliper out slightly.
Both will need larger than the standard 13s though
Posted on: 2012/9/9 2:51
Re: Brakes
From Brisbane Qld
Ok and do u keep the master cyclinder Or up grade that to?
Posted on: 2012/9/9 4:58
Re: Brakes
From Trinidad and tobago
Double reservour master cylinder is the better way to go.
Posted on: 2012/9/9 9:45
'71 Four Door Sedan.
Street Sleeper!
STILL LIVIN' THE 70'S LIFE !!
Re: Brakes
From Brisbane Qld
So i could recondition my master cylinder? And how Do i Double reservour
Maby make a coustom one?????
Posted on: 2012/9/10 11:15
Re: Brakes
Your master should be double res already one for fronts one for rears. Might.be able to.be recoed.
Personally I hate boosters in the datsuns. Every one seems to have issues with them.
Posted on: 2012/9/10 11:53
Re: Brakes
From Brisbane Qld
So i dont realy want to wait till it fails on me like i said At the lights the pedal Goes
Down under the foot i to have replace the back shoe,s soon.
Then i can a just the hand brake and sit
at the light,s out of gear with hand brake on. Like ya should Maby that might make last longer???
Posted on: 2012/9/10 19:32
Re: Brakes
Surely if the pedals sinking that much there's a leak somewhere?
Have you replaced fluid and bled the system?
Posted on: 2012/9/10 23:00
Re: Brakes
From Wanneroo, Western Australia
Fluid is either leaking externally or internally.
If you're constantly having to top up your fluid, then you have an external leak. The most likely culprit would be the rear wheel cylinders but if there's no evidence of leaked fluid in the drums, check every part of the braking system until you find the leak.
If the fluid level in the reservoir hasn't dropped, you have an internal leak. This means the primary seal in your master cylinder is buggered, allowing fluid to seep past it and back into the reservoir when the pedal is depressed. You can recon the master cylinder, but the easiest fix would be to get an exchange one. I swapped the master cylinder in my Navara about 3 months ago and the exchange part cost me about $200.
Posted on: 2012/9/10 23:15
Re: Brakes
From Brisbane Qld
Yeah ok that makes a lot of sence i have new Brakes shoes for the rear waiting at the work shop maby i not put them on untile i Get some wheel cyclinders and some cash for The reco master.Thanks every one For your reply,s
Posted on: 2012/9/11 0:36
