exhaust manifolds GX vs H99
From Fremantle, West Australia
Have any of the Datsun Gurus out there ever measured the flow/ efficiency/ power difference of the various factory Datsun exhaust manifolds?
I am guessing the GX is the best otherwise the speedway guys and gals would use something else.
Is a 1200 GX (dual outlet) significantly better than the 3 bolt 1500 (single outlet) H99 Sunny/Vanette item?
Could it be that the Nissan engineers simply switched to manufacturing the single outlet on later A15s to reduce the cost of exhaust pipes?
Posted on: 2012/9/9 3:27
Re: exhaust manifolds GX vs H99
From sydney.nsw
yes mal. i have flowed all of them & all flow different. heads & manifolds.
GX stuff comes out on top (head & manifold)
note; also depends on other things aswell
Posted on: 2012/9/9 3:39
A.T.E RACE ENGINES: ( " AUST 1 " 2010 ) A15 GO THE DATTOS... 0412 864 741
Enlargerning the outlet on the H99 has supposedly some improvements and one Ill be going for and can be done by a good welder.
Starting from sanblasting a H99, heat to 400 celcius then build up with bronze on the walls near the outlet lastly enlarge the outlet or as Ive seen on a Midget datsun powered race car just the flange area cut and shut with a bigger one from something else.
Not sure on the performance improvement but the Midget cut and shut is still going strong for last 14 years.
Posted on: 2012/9/9 6:58
Thanks Ernie
So assuming you had a very stock A15 (cam, head,carby etc), do you think there would be a noticable improvement between an H99 and a GX exhaust manifold?
Also how did the C22 Vanette "dropdown" manifold compare with the H99?
Posted on: 2012/9/9 11:07
From sydney.nsw
pm sent.
Posted on: 2012/9/9 12:01
