A12 Turbo Help!!
Not too shy to talk
From Pakistan Islamabad
Hi all, How are You Guys??, i have a AiResearch M27, or Garrett T3 Turbo setup complete with intercooler piping and BOV, i want to install it in my A12, but am confused, is the turbo too big??, how much boost is safe on stock internals?? and how do i go about it? what items will i need?
Posted on: 2012/9/16 18:30
Re: A12 Turbo Help!!
Search the wiki or use the search bar- lt's all been covered before.
Just need manifolds (which are custom) and piping. Choose efi or Carby (draw or blow through) etc etc
Posted on: 2012/9/16 21:51
especially look up topgear and supafatto as usernames
Posted on: 2012/9/17 2:00
:) T3 is to big for A12, I'd go smaller! I had a t25 custom piping and ran 7psi!
Stock internals will deal with 10psi but MUST be cooled! There's heaps around! You'll need to decide efi or carbi, then budget, and go from there
Posted on: 2012/9/17 9:54
Car free
Not too shy to talk
Thank you All for the Replies, @unfamilia, thanks i did search, but i wanted to know f anyone has specifically used a T3, @ D, thanks,
@supafatto, Thanks alot for your advice, i have a few questions though, i hope you dont mind, :)...
i want the boost to come around 3500 to 4500 RPMs, can the T3 do that, i dont have much choice on the Turbo as its the only one i got, here in Pakistan its very difficult to find turbos in good condition, and the ones that are are way to expensive, Is 8psi safe? how much HP was Yours Pushing with 7psi?? and most importantly i will be doing it on a Carbie, i dont have much cash to spare, The intercooler is a top mounted one, would that work?, i have seen images of projects with the box system on the carby, is that better? what would i need to upgrade, like carby jets e.t.c, there are rubber pipes for the turbo to intercooler and to carby, would that do?, what should the diameter of the turbo manifold be? and exhaust pipe? sorry for so many questions, i hope you can help me out here... thanks a million, brother :)
Posted on: 2012/9/17 12:25
With a t3 I'd expect boost to come on very late over 4500rpm, as far as jet size depends on carbi being used!
As for the rest cooler piping most use 2.5inch or 64mm, steam pipe and around 1 1/4 inch steam pipe I think!
Posted on: 2012/9/17 12:31
Car free
From Adelaide
If funds are limited a draw through set up with water injection may be a good option. There are some pretty simple ways of squirting in some water. A good rule of thumb is to limit water flow to match maximum fuel flow. You might need to bust out your calculator.
Simplest system I've seen uses boost to pressurise the water bottle and squirt water in before the turbo through a fine atomiser (spray head), you need small droplets to avoid eroding the compressor quickly.
1200 Coupe A15E - ITB
Lamb Daiquiri - a man's cocktail!
Not too shy to talk
@supafatto, ok, i will look for a good T25, but if i cant find one due to limited resources in this country, is it ok if i go with the T3?, the carby is a Hitachi DCH306, i think the standard A12 caby, although no vacuums are connected as i am running a performance Air Filter...
ok then i should custom make the pipes ad not use the rubber ones, right?
Posted on: 2012/9/17 12:41
Not too shy to talk
@lamb_daiquiri, i have never seen a draw through setup, can you guide me here, thanks
Posted on: 2012/9/17 12:42
Not too shy to talk
how fast does a T25 spool?
Posted on: 2012/9/17 12:44
