a15 pinging when slightly hot and missfires
From mandurah
hey everyone ,been having dramas with my a15 and im thinking of ways i can fix it
well i have a fairly worked a15 with twin 40mm carbs 12:1 comp cam and a rebuild aswell as a heap of other stuff
at the moment im running an msd 6al2 ignition box with a bosch mec717 coil and has been awesome and was a noticable different in torque from my old stock coil and points ,plus it has a limiter and launch control
now ,when i am doing (i know it sounds bad ,but its at the drags) a burnout ,it will be fine and easyily hold 3rd gear on the spot with both wheels
1) under load for 20 odd seconds ,starts to ping when slightly past half on gauge
2) 3/4 down the track it will splutter and miss so i get off the throttle ,as i come back to the pits it is running on 3 cylinder(maybe 2! ) and then if i give it a squirt in a straight line after letting it cool down it will clear up and be fine again
3) if i hold a burnout on the spot for about a minute it will start pinging and will only be slightly over half on the gauge
motor never gets hot ,it sits on half on the gauge on the freeway fine and doesnt get hot in traffic
so im thinkiing the plugs are getting too hot and are glowing and causing the missfire ,that cylinder floods then clears up after a big squirt
im running bpr6es plugs and it didnt used to do the misfire when i was running bp4es plugs
i was looking on youtube and am considering water injection as a fix for the pinging as it would lower intake temps and control pinging at the same time as giving it a little more power
anyone know what plugs i should be running and if water/meth is a doable thing with 4 intake tracks???
also i have the timing set at 10 deg static but need to recheck total timing ,if i run water injection i can run timing to make more power but still have the pinging sorted
cheers
http://www.youtube.com/watch?v=Zeervwwj_IQ drags
Posted on: 2012/10/14 15:46
Re: a15 pinging when slightly hot and missfires
From south australia
Thats pretty high comp are u running a race fuel or premium fuel in it. Poor quality or low octane fuel could cause that maybe. Usually pinging is caused by 2 much advance but surely 10 deg would be fine unless ur dizzy is advancing heaps but that would be a constant problem in revs not just when hot. I would try hotter plugs. I dont have a part number but i have some that would handle what u need. i can check part numbers tomorrow if needed.
Posted on: 2012/10/14 17:51
The meaning of life is not in the fridge..
Its in the shed....
From Trinidad and tobago
Just a heads up.
I run bp5es in mines.
Posted on: 2012/10/14 18:39
'71 Four Door Sedan.
Street Sleeper!
STILL LIVIN' THE 70'S LIFE !!
From Malaysia
try one range colder, try BP7ES.
Posted on: 2012/10/14 19:31
From Ballarat Victoria
The temp guage only tells part of the story. I`d recommend running a genuine water pump(with a cast impellor) and a high presure cap. This will help maintain block presure and prevent nuculate boiling of the coolant around the combustion chambers and exhaust seat area. This will drop combustion chamber temps and help prevent detonation.
I`d also be using 6`s or 7`s(plugs).
What is the Air/fuel ratio under full load, and what fuel are you using?
Posted on: 2012/10/14 23:55
VIC DYNO HIRE
From Perth
Why are you running a resistor plug ?
And start saving for a stronger diff with LSD
BP6EY would be something to try
Non resistor and the Y plug has a V groove electrode for a fatter spark
Posted on: 2012/10/14 23:59
The other thing it could be is, fuel vapourising in the lines after a long burnout causing high under hood temps.
Posted on: 2012/10/15 0:21
VIC DYNO HIRE
From Gold Coast,QLD.
I am running A15 with 12.5-1 comp ratio and i mix 20% toulene with 98 octane fuel to boost "RON" to approx 102,that sorts pinging out quick smart.You could try some octane booster from your local automotive supply stores i.e. autobarn,supercheap etc.That would be a cheap way to check if it sorts it out or not!Also depending on winter/summer conditions i do use BP5EY/BP7EY respectively.Hope this can be some help.
Posted on: 2012/10/15 6:09
SLICK & SMALL IS THE WAY TO HAUL!!!!
From mandurah
Awesome fellas
i went to buy new plugs and was told bpr plugs were the same as normal bp plugs
ill definitely change the plugs today
as for fuel i only ever run bp 98 , sometimes i add octane booster but it does do much apart from make my plugs orange ! Haha
what gap should i be running them aswell? .8?
diff is the next thing im going ,looking at getting a ute diff shortened ,as im running a h145 locked at the moment
where can i buy toulene? Just a panel and paint shop ?
Also the water pump is new ,does it have to be te cast impeller? also what do you mean by high pressure cap ? Would a 13psi cap be enough?
Thanks everyone!
Posted on: 2012/10/16 2:29
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
You can get 20 litre drums of Toulene from your local Paint supply depot or distributor,i get mine from Wattyl Paint Depot,$77.00!It works out approx $2.05 liter mixed depending how much you pay for 98 fuel.I mix 4 lt toulene with 16 lt 98 fuel.
Posted on: 2012/10/16 2:52
