1979 Datsun 210 GTL RACECAR Racecar has a long race history from manufacture date. Racecar is a roller with many upgrades. Painted in Nissan factory race colors, it has been to the National Runoffs several times and finished in the top 10 and won the 2007 SARRC. Significant upgrades to suspension, coil over's springs, 200SX struts, vented rotors with 4 wheel disc brakes. All Suspension is heim jointed for total adjustability. Extensive roll cage, OMP Carbon Fiber race seat with 6 point race harness, custom aluminum Griffin radiator, oil cooler, remote oil filter setup, all AN fittings and steel braided lines, Electromotive crank fire ignition, Tilton peddles and Tilton brake and clutch master cylinders with remote reservoirs, Lexan all the way around, flared fiberglass front fenders, fire suppression system, upper and lower sway bars, all gauges and TACH with Shift Light, very rare Original Detroit Locker 411 differential plus other differential ratios, fuel cell, lightweight racing rims and slicks. Spare front air dam, brand new - painted and clear coated. Out of racing and must sell ... many other spares so everything goes. Will part Racecar if you need something specific, additional set of light weight racing rims. Also, have 3 spare cranks - a couple are light weight racing cranks, 5 new factory cams, cam gears/chains, stock 4 spd…etc. several ported intakes, Weber Carbs (complete set-up with AN fittings and steel braided fuel lines, Ported Heads...etc...... $2400 OBO Barry Brannon St. Cloud, FL 407.334.8887
Posted on: 2012/10/13 3:02
