cam specs, are theese too wild?
Hi all looking at these Cam specs compared to a sss Cam. IM running an l16 with l18 crank and rods with l24 flat top pistons. IM hoping will clear pistons and also would it work with straight Lpg and a custom plenum set up with individual runners  Valve Timing Specifications are as follows
, Inlet Valve Timing               39   -   69
Exhaust Valve Timing        77   -   31
Advertised Duration              288
Duration @050”                     250
Cam lift                                   .285”
Valve Lift                                .428”
Tappet Settings      Inlet   .008”
Exhaust .010”
Posted on: 2012/10/17 11:42
Edited by unfamilia on 2012/10/17 12:00:28
Re: cam soecs, are theese too wild?
Here's stock specs.
Posted on: 2012/10/17 11:59
Re: cam specs, are theese too wild?
Sounds just right for a 5000 to 7000 rpm range
Posted on: 2012/10/17 20:28
My one tonner had a high lift cam with lower duration than that somewhere around 220 and 12mm lift but was too many moons ago yet remember it prevented backfiring due to overlapping compared to a longer duration cam I used earlier which damaged my previous engine.
Another thing is gas needs 30% more volume than petrol so are your runners and plenum bigger than an injected version would be? Looking at your manifold and an efi online its a close call.
Posted on: 2012/10/17 23:44
Plenum and internal volume about 10% bigger than stock efi manifold.
Looking at a higher comp head with 40mm Ports and larger valves. This is the Cam on it. I just can't loose too much vacuum down low or the car won't start but Cam guy said smaller Cam not great up top. More low and mid range. I'd rather but more mid and top so low down torque loads not too great. IM no burn out or drift guy. I like corners fast sweeping bends
Posted on: 2012/10/18 0:07
From Geelong, Vic
whats stock duration like? as the lift isnt really much bigger than standard, its less of a jump going for an l18 cam to that one than it is from an early l16 to a later l16 cam
Posted on: 2012/10/18 0:10
